CV carb support Bracket
Old 11-03-2013, 07:59 PM
cajun1957a's Avatar
cajun1957a
cajun1957a is offline
Default CV carb support Bracket
I have a 74 shovelhead that I have redone the top end. I put on the CV carb a velocity stack that adds considerable weight. Can some one recommend some kind of support bracket that will work with this set up. There are what appears to be mounting holes on the bottom of the rocker boxes between the tubes that appear to be mounting place.
randy
Old 11-03-2013, 08:09 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is online now
Received 4,557 Likes on 2,884 Posts
your bottom bolt on the manifold could attach to the center bolt on the engine block with a bracket they sell that is adjustable, for different lengths between the 2 connections -- johnjzjz
Old 11-03-2013, 08:54 PM
cajun1957a's Avatar
cajun1957a
I was thinking of something like that but wasn't too keen on loosening that engine block bolt incase it cracked the seal, but then again I think that is where it would make sence to put it. Who sells them, im in Ontario Canada? Thanks
randy
Old 11-03-2013, 09:22 PM
johnjzjz's Avatar
johnjzjz
randy
i have never had an issue with taking the nut off one side of the cases and installing a bracket
V twin i believe has them and everyone had sold them in the past its what is done from the original chopper days foward when changing out to any carb - early shovels had a bracket off the front head underneath to the air filter it also held the choke cable bendix and keihin carbs - johnjzjz
Old 11-04-2013, 09:47 AM
panz4ever's Avatar
panz4ever
panz4ever is online now
Received 3,224 Likes on 1,484 Posts
randy
Linkert carbs on pans are set up withe the mounting bracket that runs off the engine block bolt. Never been an issue. And if you think about it, you are are not going to break the seal. The cylinders are sitting on top of the case halves so that will not be an issue.
Nice looking motor you have there. Stock? modified? what gasket material did you use?
Old 11-09-2013, 03:26 PM
TwiZted Biker's Avatar
TwiZted Biker
TwiZted Biker is offline
Received 47,985 Likes on 17,497 Posts
randy
S&S used to and I think any big supplier like Custom Chrome or Drag Spec. should still carry them .
Rusty Axle
Shovelhead
03-09-2021 01:25 PM
lkr0
Exhaust System Topics
12-05-2010 05:44 PM
lkr0
12-04-2010 06:07 PM
jhr
06-27-2009 01:52 PM
gconley
03-16-2007 11:18 AM
Quick Reply: CV carb support Bracket
