adding a brake light switch to the front brake.
Old 04-26-2014, 04:39 PM
elmo4fun's Avatar
elmo4fun
elmo4fun is offline
Default adding a brake light switch to the front brake.
My ride has GMA custom handlebar controls. I've had them all apart and there is no place for a switch to activate the brake light. So I figure I'll just put a pressure switch in. Problem is, there is no banjo fittings to put a banjo bolt switch in and the front brake line is all one piece. Any cost effective ideas?
Old 04-26-2014, 05:27 PM
Jbic68's Avatar
Jbic68
Jbic68 is offline
Can you something like the old enduro bikes. Drill a little hole in the brake perch and use a switch that is activated when you pull on the lever.
Old 04-26-2014, 05:33 PM
elmo4fun's Avatar
elmo4fun
elmo4fun is offline
Not without drilling thru the master cylinder
Old 04-26-2014, 06:04 PM
Joe12RK's Avatar
Joe12RK
Joe12RK is offline
Received 1,426 Likes on 885 Posts
can you remove the fitting at the end of the brake line and change to a banjo fitting?
Old 04-26-2014, 08:12 PM
Tom84FXST's Avatar
Tom84FXST
Tom84FXST is offline
Received 18,389 Likes on 5,440 Posts
Cleanest way to do it, is to mount a rear brake junction block under the lower triple tree....use a 2 piece front brake line and a regular pressure switch.
Old 04-26-2014, 08:43 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
Received 4,564 Likes on 2,889 Posts
they make a front brake switch that is the banjo bolt at the same time - it has 2 small thin wires that come out the front and can be brought back into the switch housing -- i dont have a picture of it, i have them in stock and will do one tomorrow if you want - jz
Old 04-26-2014, 08:54 PM
elmo4fun's Avatar
elmo4fun
elmo4fun is offline
Tomorrow I'll post pics of both ends of the brake line so you can see the fittings that are on there now.
Old 04-26-2014, 09:29 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
go to Mid USA motorcycle parts page 1 - 60 - banjo bolt brake switch
Old 04-26-2014, 09:34 PM
Tom84FXST's Avatar
Tom84FXST
Probably has flair fittings
Old 04-27-2014, 07:34 AM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
a GMA with out a banjo end - and i didnot read it all thats twice you caught me hahhahahaha -- i stand corrected -- jz
Quick Reply: adding a brake light switch to the front brake.
