Oil pump trouble
Old 04-26-2017, 11:54 AM
Pinetop's Avatar
Pinetop
Pinetop is offline
Default Oil pump trouble
I had a sheared woodruff key on oil Pump drive shaft at drive gear below pinion shaft. Replaced and am altogether again trying to prime Pump. I have external hose to feed port to watch oil go down in external oil reservoir. I have plenty air pressure at return port on case, just beside oil pressure port but no oil. Am I good are is this pushrods tappet created pressure? Have had much work on bike lately I have been lucky. Hopefully I will see some of you for Texas evo meet!
Old 04-26-2017, 02:35 PM
Dr.Hess's Avatar
Dr.Hess
Dr.Hess is offline
Received 2,739 Likes on 1,359 Posts
Pull the plugs out and crank it until the light goes out.
Old 04-26-2017, 03:49 PM
glidein wide's Avatar
glidein wide
glidein wide is offline
Remove check ball cap,when it fills with oil, replace cap.
Old 04-28-2017, 01:08 AM
Pinetop's Avatar
Pinetop
Pinetop is offline
Default I have sifton oil Pump and it did not have diagram
Cant tell which one u are referring to one has a spring and cylinder and the other has spring and ball. In the past I would attach outside source of oil above engine but I installed new Pump fitting and stainless lines making it a PITA to use old method. Someone familiar with sifton pumps?
On another note Granite State Harley took down their Online parts diagrams for all Harley's and now I do not have a similar resource. Can someone PM me a current online source? Don't want big brother to strike info so please pm.
Old 04-28-2017, 05:49 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 8,533 Likes on 4,632 Posts
Old 04-28-2017, 11:53 AM
rol427's Avatar
rol427
rol427 is offline
Dr. Hess,
Will pulling the plugs and cranking the engine harm the ignition? I have seen comments to that effect.
Old 04-28-2017, 12:45 PM
Dr.Hess's Avatar
Dr.Hess
Dr.Hess is offline
No. There's lots of comments on the internet. If you really feel worried about it, then put the spark plugs in the end of the wires and lay the plugs on the motor somewhere, or put alligator clips on the plugs to ground them.
rol427 (04-29-2017)
Old 04-28-2017, 03:12 PM
Pinetop's Avatar
Pinetop
Pinetop is offline
thanks for info. Turns out I had trash in return gears and ill-fitting supply line causing issues. Now to set carb right after shaving another 20 thousandths off of heads. She is blowing carb to manifold gasket off on almost every start. Need to clear slow jet just in case of build-up.
Old 04-28-2017, 08:04 PM
Dan89FLSTC's Avatar
Dan89FLSTC
If the pump is not primed, you can crank it until the cows come home and the light will still be on.
The inlet side of the pump is gravity fed, and until that pump is full of oil the pressure is not going to come up.
The check ball should be removed, and oil allowed to flow from the tank into the pump, or just pour some oil into the pump and reinstall the ball, spring and cap.
Charles Fields
04-20-2018 08:44 PM
evosteveo
EVO
12-12-2017 07:25 PM
glidein wide
EVO
02-26-2016 06:17 PM
skbrown
Oil Archive (no new posts)
12-17-2012 08:47 PM
Ladder
05-21-2011 07:36 AM
Quick Reply: Oil pump trouble
