Alright sharknose audio gurus, let's do this
I'm coming from batwings so this sharknose is completely new to me. I just had to watch a youtube on removing the fairing. LOL
What's in your fairing?
What special things do I need?
I haven't seen any speaker adapters similar to BT, so do the pods have to stay on?
Hogtunes has a double amp tray and BT has a single. I haven't checked theior amps dimensions to see if what we're using will fit. Looking for feedback there.
The pods have to stay on. While you've got the fairing off, most guys remove the pods and split them to add a bead of silicone to prevent whistling. Supposedly it's possible to mount speakers in the pods without pulling them. It may be doable, but I'd end up scratching the inner for sure, so I always pull the pods to switch speaks - 5 very easy to get to allen bolts.
I use the BT adapter rings because I like BT, I'm sure there are cheaper ones available.
I also had the BT amp mount under the radio. The diamond micro 4V2 is just barely too wide to fit under the radio but it sits on top of the headlight like it was made for a RG. Anything a hair shorter than the 4V2 will fit under the radio. Also plenty of room in the cubbies for crossovers line levelers etc. A 4V2 will even fit in each one long ways.
If you really want to get creative, search for Bunker's pics of tweeters in glove boxes, very cool.
As in inside the vents? I don't see why it couldn't be done. There's a ton of room in those vents and mine are always open. When closed I don't like the air being redirected down and coming up over the tank. Try it someday in the rain and you can physically see it.
Forget the BT amp bracket, really only works with the BT amp. Same goes for the Hot Tunes and trays. Yes I bought all 3 of these and they are still sitting in the garage.
You can fit an Arc 600.4 on top of the headlight, a micro 4v2 on each side. (I removed the speaker pods to install these and it was a perfect fit.
Inremoved the radio and used all that room under there to mount my fuse block and distribution block.
I also mounted the DSP and a 4 micro there.
Basiaclly I used industrial Velcro and mounted.
Im just running the at28's in the wire grills. No drilling into my inner fairing here.
I have a thread titles 4 amps in a RG fairing with a bunch of picks. If you want more just ask.
Good luck
its fun.
Good luck
its fun.
SgtMic (04-30-2017)
I have an amp mounted on the fairing mount under the radio, an amp on top of the headlight, 4 slot fused distribution block in the right side cubbi, 4 position ground block on the crossmember under the radio.
Cam closed off his vents on his new bike, if you can check out the pics you'll see that's where he mounted his horns.
As for pods, seal them so they don't whistle but they have to stay in there (or at least the majority of the pod does ) as everything is connected to the pods to button up your fairing.
There's some pics of a Diamond 1100.6 on top of the headlight out there, that's a pretty damn big amp but will require some cutting of the fairing mount.
Soundzcustomz also offered an alternative fairing mount that allowed even more options but I don't see it on their website anymore.
SgtMic (04-30-2017)
