Handlebar control cover helicoil help
Old 12-09-2017, 02:16 PM
STRES's Avatar
STRES
STRES is offline
Default Handlebar control cover helicoil help
I have a stripped screw hole in my 2014 Dyna FXDB right side (brake side) hand control cover. I believe that this is causing intermittent brake light function because it is allowing the controls to rotate slightly. I was wondering if I could install a helicoil here and if anyone has an idea of what size I need and how to successfully do it, I believe that it will be cheaper than replacing the lower housing.
Picture of hole below.
Thanks in advance for the help
Old 12-09-2017, 06:47 PM
cggorman's Avatar
cggorman
cggorman is offline
Received 2,291 Likes on 1,710 Posts
Should be a #10-24 screw thread. Order the complete helicoil kit for that size. It should include the special drill, tap, installer tool, and the coils.
It's pretty straightforward. Check YouTube for installation videos.
Since it's a blind hole, you may also want to make or buy a drill stop collar to prevent drilling too deep. You should be able to get them at any decent hardware store or just wrap huge ring of duck tape around the drill at the desired depth.
Oh, and since you're asking, I'm guessing you may also need a tap handle. A 8-pount socket or vice grips can work in a pinch but you.must exercis extreme care in keeping a good grip and tap angle.
Old 12-10-2017, 12:25 AM
Rasputin666's Avatar
Rasputin666
Rasputin666 is offline
you can get those covers fairly cheap though 😂
Old 12-10-2017, 05:33 AM
SSteve_SSteve's Avatar
SSteve_SSteve
SSteve_SSteve is offline
Im willing to bet you will be better off and end up cheaper by just replacing the cover.
Old 12-10-2017, 05:59 AM
Iceman24's Avatar
Iceman24
Iceman24 is offline
Received 2,228 Likes on 1,627 Posts
^^^This^^^
You already have the cover off...just replace it...probably less cost than getting all the parts to fix.
Old 12-10-2017, 09:43 AM
CJD197's Avatar
CJD197
CJD197 is offline
10-24 is tiny for a helicoil. Do they even make them that size?
Old 12-10-2017, 01:52 PM
STRES's Avatar
STRES
STRES is offline
I've been searching e-bay but they are mostly touring versions that don't fit
I'm looking for
72923-11 HOUSING RIGHT, LOWER (BLACK)
Part #18 they go for about $60.00 which I thought was extreme
Old 12-10-2017, 02:41 PM
cggorman's Avatar
cggorman
cggorman is offline
Probably cheaper to just buy a complete take-off switch set and save the unused bits for spares.
I think I have three incomplete sets. LOL.
$25 for both sides, complete (I think, didn't read)
https://rover.ebay.com/rover/0/0/0?m...2F192374166777
Old 12-10-2017, 07:29 PM
STRES's Avatar
STRES
STRES is offline
Thanks for all the help everyone, the street bob has a cutout on the bottom for the front blinkers so it is definitely specific. And I'm not relocating the blinkers. That's what I'm having trouble finding.
I might bring it to a machine shop that my work uses often and see what crazy price they would quote to fix it. There are plenty of chrome versions out there as people upgrade. I might try to post it in the classified/wanted section to try and get lucky.
Old 12-11-2017, 12:55 AM
Blue Bob's Avatar
Blue Bob
Blue Bob is offline
Received 1,013 Likes on 602 Posts
Pay the postage and I will repair for free. Not a problem.
Just giving back the cause
hdman6
04-27-2018 06:14 PM
can2tx
Audio Systems
09-23-2011 07:26 AM
Deuceandahalf
09-23-2010 07:36 PM
surfingspleen
EVO
01-11-2009 12:41 AM
1984fxrs
10-11-2006 12:14 AM
Quick Reply: Handlebar control cover helicoil help
