I have replaced the 15 amp and 30 amp circuit breaker. Below each breaker, there is another "breaker" part. It has "B1 truflex 15 amp"
on the part. what is this and where can I find this part?
Try the evo forum section, lots of help there.whats the problem ,why are you changing the breakers,are you good with a multimeter and do you have a harley service manual?
Multimeter, ok not great. The headlight, speedometer, brake light and starter work fine. The tach, fuel gauge and turn signals do not.They just stopped working.
Do you have the harley service manual,with the wiring diagram? If not I may have the diagram in my FLT manual which has the FXR too.I may be able to email you the diagram.
One more thing, I had problems due to crappy mylox connectors not making good contact,you may want to check them first.Those are the multi pin connectors.. Mines also 32 yrs old,lol
The two bottom breakers were pulled out leaving their casings. I pulled the casings out leaving the holders. May I use a 30 amp in place of a 15 amp? My email is pferretti01@comcast.net The diagram would be very helpful. Thanks
i'll send you the diagram,as far as the breaker ,stick w/ a 15A
