2013 electra glyde ultra
Old 04-17-2019, 09:12 PM
Joseph Learn's Avatar
Joseph Learn
Joseph Learn is offline
Default 2013 electra glyde ultra
Been reading through all the forums for over a week now, and there seems to be a ton of different options and opinions! (Thank you for the wealth of information!)
I'm considering redoing my audio, as right now it's just a mess of distortion at any level loud enough for hwy speeds. It's currently all stock. A lot of the options I have found also seem to be for 2014 and up..
I listen to a wide range of music types also,
I don't need pro audiophile stuff, but I'd like it to at least sound good without distorting. I'm not opposed to replacing the HU and adding an amp, but I rely on FM for about half my riding when my phone has zero signal, which also has me confused because a large majority of the posts seems to say you lose FM signal with the addition of an amp.
I'd like to start out with the stock stuff, possible additional lower fairing speaker pods would be okay also. I'd like to keep my handlebar control functions also.
Budget is around $1000 or so, can go higher if need be to get it done right the first time.
Any suggestions would be awesome!
Old 07-16-2019, 05:58 PM
Joseph Learn
Sony MEX-M100BT with handlebar controls kit for a HU? I could care less about the satelite radio, or the CD. I use mostly FM and sometimes BT from my phone
Amazon Amazon
Mmats601cx for fairing and tp? Do I need spacers or grills?
That HU pushes 100wattx4, do I still need an amp? FM reception is very important to me.
Thanks again
Old 07-16-2019, 06:08 PM
USAproud's Avatar
USAproud
USAproud is offline
You will still want an amp. You will need metra 82-9601 adapters for fairing. You will also need spacers for tourpack and grills for them as well. Unsure of exact size spacer since i havent used those speakers.
Old 07-16-2019, 07:21 PM
Joseph Learn
Thank you for the quick reply!.
From what I read I want either a Arc moto 600.4 or the stinger 700.4 to maintain FM?
Old 07-16-2019, 07:39 PM
Bluesman280's Avatar
Bluesman280
Bluesman280 is offline
The Spacer I used on my 2005 tour pack was the VTwin speaker adapters. They look good, they fit nice, and the Mmats 601.cx will work with those adapters. They are a bit pricey but they do come with grills. You still have to rotate your speakers to a happy spot and notch a little bit of material out of the inner ring on the pods with a Dremel, but all well worth the effort.
The Mmats are a good choice.
Old 07-16-2019, 07:46 PM
Joseph Learn
Thank you very much!
Old 07-16-2019, 09:07 PM
marcodarq's Avatar
marcodarq
marcodarq is offline
The mmats pa601.4cx speakers do NOT come with grills, they need to be purchased in ADDITION to the speakers.
M
Old 07-16-2019, 09:19 PM
Joseph Learn
M
Yeah I saw that. It was $118 for water proofing with grills and rings direct from their site.
Thank you for the heads up tho!
Old 07-16-2019, 09:51 PM
eggwhite93's Avatar
eggwhite93
eggwhite93 is offline
Anyone have pictures of the MMats grills? I’m having trouble finding one.
Old 07-17-2019, 02:45 AM
Joseph Learn
I couldn't find a picture of the mmat grills either
Quick Reply: 2013 electra glyde ultra
