Removable tour pack ?
Old May 10, 2019 | 05:24 AM
hog dog 82's Avatar
hog dog 82
Default Removable tour pack ?
Put a removable tour pack kit on my 2018 Ultra Limited. When I take the tour pack off I have know place to put the wire harness. Don't want it flopping in the scratching the paint on the fender and bag, any suggestions?
Thanks
Old May 10, 2019 | 05:51 AM
BelchFire's Avatar
BelchFire
I used small adhesive
zip tie anchors zip tie anchors
to keep the loose ends from flapping (and to keep the excess wire from scuffing my paint).
Old May 10, 2019 | 09:35 AM
MegaJohn's Avatar
MegaJohn
I installed a tour pack on my 2009 UC last year. I was able to extend the wire harnesses so they connected under the seat. So, when I disconnect they're all tucked away under the seat. I know the connections are different for the later models (I don't even know if you have to take the seat off)... but that's what I do.
Ride Safely!
John.
Old May 10, 2019 | 01:04 PM
GalvTexGuy's Avatar
GalvTexGuy
I roll mine up and stuff it under the seat.
Old May 10, 2019 | 01:30 PM
Oko's Avatar
Oko
Same here. You can put some pipe foam over them. I read that on the forums here somewhere.
Old May 10, 2019 | 01:42 PM
cprhed's Avatar
cprhed
You jam them damn things up under that seat like you're stuffing the thanksgiving turkey.
Naw really it ain't that bad. I even have a driver backrest mount under the seat and there is still plenty of room. Use some small zip or velcro straps to keep them neatly together so they aren't just loose like an old ball of yarn and it will be fine.
Old May 10, 2019 | 07:36 PM
hdbob2006's Avatar
hdbob2006
I use wire ties to tie mine to the rear wheel.
Old May 10, 2019 | 10:57 PM
cprhed's Avatar
cprhed
It fits
Old May 11, 2019 | 08:06 AM
heavymetalthunder's Avatar
heavymetalthunder
That's what I do also.
Old May 11, 2019 | 02:41 PM
Hammerhead Pat's Avatar
Hammerhead Pat
But then the OP would have to remove the screw that holds the seat in place.....
