Derby cover won't stop leaking?
Hello all. I got a great deal on a 2013 Sportster last summer. It had been laid down but only needed a few cosmetic items replaced. The Derby cover was also cracked. I replaced with an ebay derby cover. I couldn't get it to stop leaking even after multiple new gaskets. I ordered a different ebay derby cover. Again, I cannot get it to stop leaking after multiple new gaskets.
I'm not a mechanic. But I'm not a total idiot.
Over the years I typically haven't needed to use any sort of gasket sealant on rubber gaskets. Do these require something?
It's interesting. When I install a new gasket I will run the bike up to 20+ minutes with no leaks. Then after the bike cools back off it's leaks nonstop. And then doesn't stop leaking.
The primary cover looks in great shape. No road rash and everything lines up perfectly. But that may be my next replacement. Unless the community here has any suggestions?
I appreciate any opinions you guys might have. What would you all try next?
Thanks for bringing that up. Yes I am. In fact the last couple times I torqued it down, I started at 40in lbs (from memory) and did it in 5 steps. Went all the way around in star pattern. Increased a bit... went around again. Increased a bit... went around again. 5 times. Up to book spec which (from memory) is 90-120in lbs. I was overly cautious of warping the derby cover. Thank you.
Received 19,838 Likes
Other than that I have nothing. Good luck and let us know what you find.
Hathaway (05-11-2024)
