2018+ Softail Models Breakout
Auxiliary light switch function How to
Old May 3, 2022 | 05:45 PM
Feileod's Avatar
Feileod
Default Auxiliary light switch function How to
Quick how to, I wanted my Aux pod lights on my 2020 FXLRS to use the OEM switch. Here is how I did it.
All left switch controls, including the cruise control version, have the aux light button. When you remove the left turn signal switch cap you will see it to the right.
The Aux light function is already enabled and does not require a trip to the dealer to program. However; the wiring is incomplete. You will see there are four wires on the female connector side and only three on the male connector side. The Blue wire with the Black stripe is the Aux light power. You will need to connect to this wire to power your Aux lights.
Once you have your lights wired up you can either modify your existing turn signal switch cap or purchase the Heritage classic switch cap from the dealer.
Un-modified cap
Modified cap
Heritage cap
Heritage cap installed on left switch controls with cruise control
Once everything is in place tap the switch. You should have your lights come on and the green icon light up on the speedo.
I hope this helps anyone wanting to run some Aux lights on their Softail.
Old May 4, 2022 | 06:38 AM
MoneyFor's Avatar
MoneyFor
Originally Posted by Feileod
Quick how to, I wanted my Aux pod lights on my 2020 FXLRS to use the OEM switch. Here is how I did it.......
Great info
Old May 4, 2022 | 07:04 AM
470004's Avatar
470004
Great work. Thanks for the information.
Old May 4, 2022 | 07:27 AM
mrcribbs's Avatar
mrcribbs
Where is that connector located?
Old May 5, 2022 | 08:34 AM
Feileod's Avatar
Feileod
The turn signal connectors are located in the neck junction block behind the rubber plug. Follow the wires from your handle bars down the triple tree and back towards the fuel tank, you'll see the rubber plug covering the hole in the frame.
Old Feb 5, 2025 | 09:36 PM
ELBrandon's Avatar
ELBrandon
Stage I
Do you think I could wire my S2 aux lights to this switch or will it overload my harness?
Old Feb 6, 2025 | 01:26 PM
deperdue's Avatar
deperdue
This works from 2018 through 2023 on lowrider, lowrider S, and lowrider ST
Old Feb 7, 2025 | 07:12 AM
natural gasser's Avatar
natural gasser
Excellent write up. Fairing and pods look great too, nice work.
Old Feb 7, 2025 | 12:07 PM
streetmaster56's Avatar
streetmaster56
Nice write up, out of curiosity i popped my turn signal cap off on my 2021 bob to see if that hidden button was there, sure enouygh plus the harley extended caps already have the mod in tact and work like a charm. Been wanting passing lamps as well, so i managed to score a whole like new set-up from a heritage along with the tree's in order to mount them up off ebay.
Old Feb 9, 2025 | 08:14 PM
Feileod's Avatar
Feileod
I would think yes, those shouldn't be much more draw than typical aux lights. If it were an issue you could use a relay in conjunction with the switch and it would work fine.
