Engine Light, Security Light & Check Engine Light
Old 05-03-2024, 09:49 AM
watson's Avatar
watson
watson is offline
Stage IV
Default Engine Light, Security Light & Check Engine Light
I have a 2005 Electra Glide Classic.
While riding home yesterday, the check engine light came on, then battery, then security key. They seemed to rotate which was on, and off. None remained on constantly. And, I should add, there were periods of 5-10 minutes when no warning lights were on. Bike was running fine, but every now and then, the speedo would drop to 0. I assume this is from a now power issue.
I have checked battery connection, and fuses, and all seem as they should.
Any one have a suggestion as to where I could look for the culprit?
Old 05-03-2024, 11:51 AM
Keithhu's Avatar
Keithhu
Keithhu is offline
Received 5,404 Likes on 2,635 Posts
Yes, start by capturing the codes and report back.
62hdbiker (05-03-2024)
Old 05-03-2024, 05:24 PM
watson's Avatar
watson
watson is offline
Stage IV
I am getting a U1097 code.
would that trigger the security light and battery?
Old 05-03-2024, 05:41 PM
GalvTexGuy's Avatar
GalvTexGuy
GalvTexGuy is online now
Received 3,998 Likes on 2,201 Posts
After reading several threads/posts on the code, I learned it could be caused by several issues. Rather than posting all the responses, I’ll give you this link and you can read for yourself. Copy and paste into Google.
U1097 code site:www(dot)HDForums(dot)com
Old 05-04-2024, 01:39 PM
hattitude's Avatar
hattitude
hattitude is online now
Received 7,557 Likes on 4,085 Posts
Did you check the battery? I would do a load test, to ensure you have a good solid 12V source..
Once your 12v power is verified as good (good battery, good cable connections to include grounds & good fuses), with that code, I would check the VSS (vehicle speed sensor).
Are your turn signals self-cancelling with no problem? That is another sign of a bad VSS.
When checking the VSS, if you find it with a lot of metal shavings on it, first clean it off and try running it again. That may fix the problem. If the code returns, then test the VSS, and/or on a 19 yr old bike, just replace it..
Keep us posted on your progress....
Mchad
12-10-2023 03:55 PM
Tommy B
06-09-2020 11:52 PM
mikeferns
05-02-2018 07:45 PM
Softtail Bob
05-13-2007 08:44 PM
Inforit
07-17-2006 04:54 PM
Quick Reply: Engine Light, Security Light & Check Engine Light
