Shovelhead with Super E Cranky Cold Starts
1984 FXSB with S&S Super E, Ultima programable ignition and dual plug heads. Intake seals are less than a year old.
Super E has .032 pilot, .72 main and mixture at 1.5 turns.
Engine starts right up warm and runs great thru the entire rev range. Cold start it is cranky. With the enrichener up it will crank and cough (electric starting). I find I have to give it several twists of throttle (like over 7 twists) to get it to fire. Once it does fire I have to wait quite a bit (few minutes) before I can push down completely on the enrichener lever otherwise it will stall. No issues if I shut the bike off for several hours... pull the enrichener up and it fires right up. It's when it sits for over a day that I find it needs several pumps to get it going.
Almost seems like the bowl goes dry. No fuel dumping out of the overflow when it sits.
Nature of the beast?
The following 2 users liked this post by TwiZted Biker:
FLHS1990 (05-12-2024),
Spanners39 (05-09-2024)
Will try those smaller jets (it does seem a tad fat on the jetting). I have the timing retarded a bit due to the dual plug heads (timing mark on the left edge of the timing hole). I will check what curve it is on.... no pinging issues..
Received 5,052 Likes
With the Tech Cycle starter and Anti Gravity battery it spins over real nicely.... just requires a lot of twists of throttle to get it primed (will be trying all suggestions here this weekend).
