Compensator
Old May 16, 2025 | 04:01 PM
Daniel_R's Avatar
Daniel_R
Default Compensator
Yep. Another comparator question.
is there a way to tell if your compensator is bad without totally removing it?
Old May 16, 2025 | 04:51 PM
Max Headflow's Avatar
Max Headflow
It knocks or rattles.
Old May 16, 2025 | 05:13 PM
Daniel_R's Avatar
Daniel_R
it did but the whole thing does that. I took it out already.
Compensator spring pack rattles when I shake it.
Old May 16, 2025 | 05:22 PM
Max Headflow
They can rattle and still be good. Look at the splines that the sliding cam runs on. They typically wear out..
Old May 16, 2025 | 07:21 PM
Daniel_R's Avatar
Daniel_R
You got that right.
I looked further and found out how there could be little tiny pieces of metal on the magnet in the drain plug…
Compensator blues 1
Compensator blues 1
Compensator blues 2
Compensator blues 2
corresponding part is pristine. Got the call into HD to see if they have a compensator in stock.
Old May 16, 2025 | 07:31 PM
Max Headflow
I'd say you found it.. You'll need the kit with the SE comp and new alternator rotor. Use JB weld to install the deflector.
Old May 17, 2025 | 08:09 AM
Daniel_R's Avatar
Daniel_R
yep. Thanks.
hope they got one in stock. I’ll be jonesing in no time.
Old May 17, 2025 | 02:04 PM
Daniel_R's Avatar
Daniel_R
Got a new compensator, they had one in stock.
I’ve dealt with Redline Harley twice now and no complaints about the treatment. the parts people are peaches!
new compensator is installed and ready to go when the JB weld is dry enough… about 11:00 am tomorrow.
Old May 17, 2025 | 02:19 PM
dynoking's Avatar
dynoking
Sorry to be a Johnny come lately. Is the chain tensioner the latest version?
Old May 17, 2025 | 02:32 PM
Max Headflow
If you look at it, it's an 06B. Nothing wrong with the 06A if it's working for ya.
