M8 idle delay
Old Apr 4, 2026 | 03:02 PM
Hoginedgewood's Avatar
Hoginedgewood
Default M8 idle delay
Its a 19 RK, mostly stock except for the exhaust. When I come to a stop im a couple hundred rpm's too high, but within a minute or so all is good. Any suggestions?
Old Apr 4, 2026 | 03:21 PM
2017M8's Avatar
2017M8
To reset your idle setting back turn the ignition switch on then off for a total of 10 times (do not start the engine). That should reset your original throttle position.
Old Apr 5, 2026 | 06:29 AM
Hoginedgewood
thanks I will try that, but I'm not sure you read the last part of what I said.
Old Apr 9, 2026 | 12:11 PM
Sparkules's Avatar
Sparkules
Another issue doing this would be an intake seal leak usually at the manifold to head seals.
Old Apr 10, 2026 | 06:54 AM
Old Sport's Avatar
Old Sport
Does this also happen when you’re stopped and blip the throttle?
May be a lean condition.
Old Yesterday | 04:37 PM
2017M8's Avatar
2017M8
Has this been Solved ?
Old Yesterday | 06:05 PM
Hoginedgewood
Haven't ridden lately, motor is stock except for the cat. Sounds like the intake seals would be the place to start.
Old Yesterday | 08:53 PM
pgreer's Avatar
pgreer
The plastic intake manifolds on the M8 can warp from heat over time and leak. So if you do the manifold to head seals, check the manifold carefully.
Paul
Old Today | 06:57 AM
Hoginedgewood
Learned this morning I have a plastic intake manifold. So if I'm going that direction sounds like S&S or a competitor, haven't checked if screaming eagle sells what they should have used initially.
or did u tube inform me incorrectly
Old Today | 07:00 AM
Hoginedgewood
Paul
thanks, I missed your post before I posted, what's the popular intake people are going with?
a $200 aluminum tube from S&S seems pricey
merv88
2018+ Softail Models
Jul 19, 2022 08:08 AM
Gordon61
May 19, 2021 04:14 PM
FrankDaTank182
Jun 11, 2016 10:19 PM
a3dad
2014-2024 Touring Models
22
Jul 31, 2015 05:28 PM
dolson911
Apr 19, 2006 07:42 PM
