FP3 Post Autotune Parameter Changes?
Old Jul 28, 2015 | 10:19 AM
a3dad's Avatar
a3dad
Default FP3 Post Autotune Parameter Changes?
Hey guys,
I just completed FP3 autotuning and must say the scoot is running great.
I was wondering what post-tune adjustments are recommended, if any. Was thinking of dropping the idle to about 950 RPM and the throttle progressivity to Moderate.
Anything other settings to consider? Thanks for any tips.
Old Jul 28, 2015 | 01:06 PM
HogPilot54's Avatar
HogPilot54
I did change the throttle progressivity to moderate. Throttle now seems more responsive. What would be the point of dropping the idle RPM?
Old Jul 28, 2015 | 02:09 PM
a3dad's Avatar
a3dad
Mostly for the exhaust note. Looking for more of that classic TD lopping sound.
Old Jul 28, 2015 | 03:42 PM
RG Pilot's Avatar
RG Pilot
Dropping that idle might make your compensator more noticeable. And maybe some other guys will chime in too but hot idle oil pressure might be on the low side as well if you drop the idle. I hear ya though about wanting that classic idle back.
Old Jul 28, 2015 | 03:50 PM
HD_Doobie's Avatar
HD_Doobie
I changed my throttle progressivity to high and really liked how responsive the bike was but later changed it back to stock. It made the drive-ability more difficult because it was so sensitive....every little movement from bumps would make the bike jerk forward.
I wouldn't touch the idle rpm's....they are set for a reason
Old Jul 28, 2015 | 07:53 PM
penmaker's Avatar
penmaker
I had set my throttle to moderate also but recently changed it back to stock. Like you, I thought it was too sensitive and hurt the drivability.
Old Jul 28, 2015 | 08:49 PM
Cobra1's Avatar
Cobra1
I like the throttle set at moderate. To me it makes it feel like my Heritage with a cable and Mikuni carb. I think setting the throttle to be more sensitive is something to try. It is always easy to go back. The idle, seems good to me at 1000 and oil pressure is at 13 hot. I don't want it to go lower.
Old Jul 28, 2015 | 10:21 PM
TcHunter's Avatar
TcHunter
Hey guys,
Did you see any thing change in your VE tables? just asking because when I did my auto tune the VE tables were the same as the base map I flashed.
Old Jul 29, 2015 | 11:09 AM
lyork's Avatar
lyork
Same here. With the progressive changed to moderate it feels real close to my older Heritage with cable and S&S Carb. I alway thought the acceleretor pump on that carb gave it some much needed pep in its step.
Old Jul 29, 2015 | 06:45 PM
bill_1202's Avatar
bill_1202
There is no "high" setting for the throttle. The choices are standard, standard plus, moderate, aggressive, race, or custom. Which setting did you have it on that made you drop it back to stock?
