2014 twin cam cam chest
I have almost 20k on my bike and a stage 4 kit and i keep seeing a good interval for lifters is 25k, less with aggresive cams. I needed new tires so i told the indy to throw a set of lifters in. He also recommended changing the tensioners. I declined since theyre supposed to be way better than the old spring loaded ones. He calls today, says they pulled the cam chest cover and they need changed. Im not even getting into price, but is the guy padding the bill or is this a legitimate concern at this mileage? I dont use mechanics often because ive been screwed by quite a few and im kind of wondering if this shop should have just lost my trust or if this is a good call by them.
Thanks.
Thanks.
If it was open I would change lifters, so you can forget about them. Id probably do bearings and pad and not open it for a very long time. Especially if you have to pay for labor.
Not saying they need it. But he will have to remove pads and lifters to get cams out anyways. IMO, they should be replaced 50-70k. I have heard of lifters going sooner, though not normal.
You replace them and you can close it up for years.
Obviously, you don’t trust the guy, so have…him…send…you…a…picture…of…the…outer…cam…chain …tensioner.
I will admit I am surprised there is much wear. But they are cheap
Your lifters failed at 20k? You already had cams done and left in stock lifters?
