Do you downshift gears to slow down or just brakes?
I have tried to do a forum search to see if there already is a thread. I can't get good results when using the search options. Maybe its just me.
Recently on a 4 day ride, a discussion came up about slowing down.
One method was to downshift and let the engine start to slow down the speed.
the other method, he said, He pulls in the clutch, does NOT downshift into lower gears and let the clutch out, but rather just relies on his brakes. His comment was brakes are cheaper than gears to replace.
Well... I know what I do. I'm curious what do YOU do and why?
What are your thoughts and ACTUAL EVIDENCE of if downshifting into lower gears is hard on the transmission. ( and I suppose to add is it hard on the engine?)
Cut my two teeth in the days of cable drum brakes that were more of a suggestion that functional then on to chopper with no front brakes, look at the machines you understand those of from that era use that transmission for a large part of stopping & braking. Ride my 17 road king same way I do the old shovel, gearbox was meant to be used.
Like it or not there is additional ware on motor, tranny and clutch with lots of downshifting. (I run solid motor sprockets) So I do it appropriately when riding circumstance call for it.. but also sparingly just when needed.
I am going to say this really is age dependent and what you learned to ride/drive with. Like Twisted said, many vehicles had limited braking capabilities and down shifting was mandatory, of course not like an f-in animal. Now just habit for us. Ask a truck driver, they down shift. But younger truckers drive automatics, things change. Good luck.
The other method is pull in the clutch lever, engine to idle, drop down through the gears, bang, bang, bang.
Or wait to downshift when almost stopped, either way if you need to accelerate you are in the wrong gear.
We have all seen posts where the op is having trouble getting the transmission into 1st gear at a stoplight (which is normal if you come to a stop in high gear
).I think the factory came out with the slip assist clutch because of the shock to the transmission by downshifting the noisy way.
Which one do you think is harder on the gears, who knows?
But I know which method makes the most noise.
