Replced Coil Wire Now Check Eng. Light
Old Apr 30, 2026 | 02:20 PM
Clutched's Avatar
Clutched
Default Replced Coil Wire Now Check Eng. Light
I have read about Coil wire Problem SM B1700.Cut Zip Tie Last Yr.Have Not Had Any Problems But Wanted To Change Wires An Plugs,So While I Had Gas Tank off I bought The Namz Wire Update For Coil Cut An Soldered Wires Heat Shrinked Covers Fit Perfect,Put Fuel Moto Wires An NGK Iraadium Plugs.Fired Right Up Now Check Eng. Light Is On,Pulled Main Fuse Still on.How do I go About Getting Check Eng. Off.Any Help Appeciated.
Old Apr 30, 2026 | 02:29 PM
rideonva's Avatar
rideonva
Don't keep us in suspense what't the code ? Did you try to clear it and see if it comes back ?
Old Apr 30, 2026 | 02:41 PM
Clutched's Avatar
Clutched
Went Out in the Garage Held Odometer Button Turned On Eng switch and Light Went off Started A few Times No Light.Never Really Had Any Problems with Codes Thats Good My Wrench Icon Came on build date 12/23 uncovered an was on this spring Piece of Black Tape fixed that.Like These New Bikes But Not The Electronics liked my old dash on my 18 Road Glide Special better no issues ever!!
Old Apr 30, 2026 | 03:46 PM
Clutched's Avatar
Clutched
Well went back in Garage Eng. Light On agin.Checked codes Says Instrument Has 1 Code #A 2559E Hit Arrow To Clear DTC Code It Has Press OK Or Cancel Pressed OK to Clear Instrument Code But Dose Not Go Thru Am I doing Something Wrong?
Old Apr 30, 2026 | 03:54 PM
rideonva's Avatar
rideonva
The only code I could find with that combination of numbers is B22559E
TRIP SWITCH FUNCTIONS INOPERATIVE, DTC B22559E
Diagnostic Trouble Code (DTC) B22559E will be set if trip switch reset is closed for more than 2 minutes. This code can be set by the Infotainment Control Unit (IFCU) or the Body Control Module (BCM). It will normally be set by both if there is a concern with the trip switch reset.
Self-diagnostics will not function if the switch is stuck. It will not be possible to toggle the switch to navigate through the different diagnostic steps in the IFCU.
Old Apr 30, 2026 | 06:36 PM
Clutched's Avatar
Clutched
Went an Goggled it found a couple videos about check eng.light an removeing codes went back out in garage an used odometer an on switch an Eng.Light is gone agin,Started several times No Light will check agin tomorrow,
Old May 1, 2026 | 05:23 AM
30glock's Avatar
30glock
Bikes ****ing with you, Just ride dude you'll be fine...
Old May 1, 2026 | 07:00 AM
jake24lt's Avatar
jake24lt
Did you remove the black tape from the screen?
Old May 1, 2026 | 12:05 PM
Clutched's Avatar
Clutched
Guess I figured Out Those Codes An Removeing them No more Eng. Light An yea still got black tape over wrench icon Like 30Glock said F***ing Ride It,Yellow Wires From Fuel Moto An Coil Cover Look Good An Replaced Coil Plug With Namz Connecter So should be Good to go,
Mr.Norm31
Jul 16, 2018 09:31 AM
Harleynoob
Electrical/Lighting/Alarm
May 27, 2015 05:12 AM
lonelyrider1966
Oct 26, 2013 11:09 AM
Whitey1
EVO
Mar 7, 2013 08:40 PM
rbrapp1
Panhead
Oct 17, 2010 12:13 AM
