Base gasket leak and other ramblings
Old May 27, 2026 | 01:13 PM
BigMike's Avatar
BigMike
Default Base gasket leak and other ramblings
I replaced all of the gaskets (Cometic) in the stock 1990 Evo. The engine runs GREAT. After a 120 miles ride a couple of weeks ago, the front cylinder base gasket has a tiny weep on the front side.
Since I'm going to replace the base gaskets (again), I'm thinking of getting the bottom of the cylinders "trued". I don't want to put it back together and have another leak.
Any thoughts?
Background and ramblings:
I sealed the entire engine with Cometic gaskets. It had less than 18k miles and there were still cross hatch marks very clearly in the cylinders. I checked the rings and they were well within spec and the same gap from top to bottom of cylinders. I cleaned up the heads and re-lapped the valves and installed new valve seals.
I did both compression and leakdown tests after about a 100 miles when I got the bike back together. The compression was 150 front and 148 rear (.030 head gasket). Leakdown at 80 psi held 77 in the front and 78 in the rear. This tells me the engine is in great shape.
Old May 27, 2026 | 01:31 PM
chopper_man's Avatar
chopper_man
Did you retorque after several heat cycles?
Old May 27, 2026 | 01:39 PM
t150vej's Avatar
t150vej
OE gaskets do not leak.
Old May 27, 2026 | 01:40 PM
BigMike's Avatar
BigMike
The can't be done without removing the rockers.
Old May 27, 2026 | 01:46 PM
Tommy C's Avatar
Tommy C
There's no need to re torque Evo head gaskets. Doing such things can result in pulling the threads for the cylinder studs out of the crankcase.
Old May 27, 2026 | 01:47 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Are the cylinder studs original, installed with the shoulder up?
If so, you may have one or more that have stretched or are pulling loose from the cases.
Old May 27, 2026 | 04:15 PM
BigMike's Avatar
BigMike
I should have mentioned that the cylinder studs are new and mounted with the shoulder down.
Old May 27, 2026 | 07:10 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Thans for the follow up on that.
A reputable Harley machinist can true the bottoms of the cylinders, just have the minimum removed.
OEM Harley gaskets are as good as any as long as you don`t need a special thickness.
Old May 28, 2026 | 06:36 AM
Racepres's Avatar
Racepres
Proper Warm-up is Mandatory to allow the "sandwich" to seal..
Old May 28, 2026 | 07:20 AM
Schex's Avatar
Schex
With a light spray of Coopercoat on the head and base gaskets, this thread wouldn't exist.
