Possible flood water damage
Old Today | 06:47 AM
SiamJimi's Avatar
SiamJimi
Stage III
Default Possible flood water damage
Dear Forum Members,
I am asking for some insight into determining if water intruded into my transmission when bike was in a flood. Best determination the water did not get above the exhaust ports, however, the oil was changed in the primary and NOT the secondary case.
My main question is how to determine if water intrusion may have affected the transmission ? should I change the transmission oil and attempt to run the bike ?
This potential for water in the transmission was overlooked by the novice owner for a period of 1 year after the flood, being a novice HD owner he was not aware of the separate oil requirements for primary and secondary cases.
I am about to drain both cases and look for water in oil, the bike was never started after the flood, only the oil changed in the primary case as a preventive measure.
Thanks, Jimi
Old Today | 07:13 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Model and Year?
Old Today | 07:48 AM
Jackie Paper's Avatar
Jackie Paper
Drain the oil in the motor and transmission. You will know. If done quick enough, it may be OK. A three hole Harley cruiser primary vents thru transmission. So if water got to primary, it went thru transmission.
If it only got to the muffler openings, your OK.
Most flood cases are total write off if you have insurance. When Isabella went thru, any car if it had a high water line mark, they wrote them off. And it didn't matter where that line was. Now it was saltwater where we are on a tributary to the Chesapeake Bay.
Stonesman57
Oil Archive (no new posts)
Jul 27, 2017 10:15 PM
jayhawkclint
Jan 7, 2014 01:52 PM
IRONCAM
Sep 15, 2010 08:01 PM
river rat
33
May 20, 2008 11:54 AM
GriffinXLCH
Ironhead
Nov 16, 2007 12:35 AM
