Low MAP stumble
I thought I would get an advice from you guys here.
Dyna 06, 98 ci (bored 2023), Andrews 57 (2026), Feuling OE+ cam plate and oil pump (2022), Fueling HP+ lifters (2026), MLS 0.030” (2026), new exhaust valves, springs and seals (2026) Power Vision Target Tune, new IAC (2026)
Crankshaft runout 0.0021” (2026), Compression front 202 psi and rear 212 psi (2026), Leak down front 6 % and rear 5,5 %, MAP at warm idle 35 kpa
When twisting the throttle the bike runs well. It has an excellent throttle response, and from 3000 rpm up to the red limit it shines.
But here are the issues:
1/ A bit of stumbling and jerking at low throttle (below 40 MAP),
2/ Cold start idle is very jerky, like it is suffocating, (began 2025 with previous cam)
3/ Some ticking noise, tracked to front exhaust valve, but had this kind of noisy valve train since three or for years, even with the previous cam
Intake leaks are ruled out with 35 kpa at warm idle. IAC was the suspect, but I changed the IAC this spring and it did not help.
I lean towards that it is a tuning issue. However this does not explain the cold start idle problem, as it began last year.
Tuning: Tune from Dynojet, autotuned 8 times, AFR put at 14,2 from idle to cruising, pulled timing 20 % at idle/cruising. I am in the process of data logging the cells in this area, but no real change yet.
If someone has a clew here, it would be great.
Thanks a lot
Oak Mountain Rider
