Looking for rigid tank bib / dash panel part for FXDF Fat Bob tank
Old Jun 15, 2026 | 01:40 PM
Dood_ltd's Avatar
Dood_ltd
Stage III
Default Looking for rigid tank bib / dash panel part for FXDF Fat Bob tank
Hi,
I’m looking for a rigid tank bib / dash cover / console piece for a Harley-Davidson FXDF Fat Bob tank.
I don’t want the soft leather tank bib version — I’m looking for a hard piece that can be painted, running from the seat area up toward the speedometer / tank console.
Does anyone know the Harley part number, aftermarket reference, or another Dyna model using the same piece?
Bike/tank: FXDF Fat Bob.
Thanks.
Cyrille
Old Jun 16, 2026 | 06:12 PM
fskitch's Avatar
fskitch
Originally Posted by Dood_ltd
Hi,
Thanks.
Cyrille
https://www.wisconsinharley.com/harl...dels-71282-04/
I put one on my super glide. Don’t care for the leather.
Old Jun 18, 2026 | 08:46 AM
Dood_ltd's Avatar
Dood_ltd
Stage III
Thanks a lot, man; that helps a ton.
Seeing your part confirmed it’s the same one, and that it fits ’06 FXD35, ’07–’11 FXDC, ’08–’10 FXDF and ’04–’08 FXDWG models. That gives me a much wider hunting ground.
So far it’s either out of stock, or the seller won’t ship to France, but I’ll keep digging with those models in mind.
Much appreciated. The search continues.
Old Yesterday | 09:18 PM
NathanielBrooks's Avatar
NathanielBrooks
Stage I
On your Harley-Davidson FXDF Fat Bob what you’re describing sounds like the rigid tank dash / console base that sits between the seat and the tank-mounted gauge area, not the soft leather bib.
Harley didn’t really offer many “hard swap” versions across the Dyna line, so there isn’t a widely shared part number that directly replaces the leather bib with a painted plastic/metal unit. Most of the factory hard pieces are tied to specific trim years or the later Dyna console assemblies, and they’re not a clean bolt-on across all FXDF models.
What people usually do is either source a used OEM rigid console top from later Dyna variants or go aftermarket fiberglass/ABS units meant for custom builds. Another option is swapping the entire tank console assembly from a compatible Dyna year range and adapting wiring/brackets.
If you’re set on OEM-style fitment, a dealer parts fiche check for your exact year FXDF is still the best starting point.
Corporate_trash
Jun 9, 2012 07:14 PM
dgdamore
Mar 3, 2011 05:42 PM
cpa55
Sep 16, 2008 01:03 AM
stl_shovel
Jan 8, 2007 08:40 PM
Amy
Jul 21, 2006 12:58 AM
