Looking for help on 2000 883 conversion to 1200
Old Jun 16, 2026 | 08:32 AM
TunanoCrust's Avatar
TunanoCrust
Stage IV
Default Looking for help on 2000 883 conversion to 1200
I have the wiseco kit and I’m going to be in the high rpm range a lot and I am using my stock heads I’m wondering if I will need upgraded valves or head work done so I don’t blow it up after I spend all this money
Old Jun 16, 2026 | 08:56 AM
eighteight's Avatar
eighteight
Are you changing camshafts ?
Are you increasing compression?
Does the bike have enough miles that the heads need a valve job at the minimum?
Old Jun 16, 2026 | 09:48 AM
TunanoCrust
Stage IV
The engine has 28k on it and I am not doing a cam and I am keeping stock compression
Old Jun 16, 2026 | 10:10 AM
eighteight's Avatar
eighteight
Then doing the heads will have no effect on your ability to "blow it up"
Old Jun 16, 2026 | 10:12 AM
TunanoCrust
Stage IV
So I should be good in the high Rpms and shouldn’t have to worry to much about bending a valve
Old Jun 16, 2026 | 10:16 AM
eighteight's Avatar
eighteight
Assuming your kit is "bolt on, no mods needed " ?
Assuming you retain the stock rev limiter, no
Old Jun 16, 2026 | 10:17 AM
TunanoCrust
Stage IV
Yes I am keeping everything stock and it is bolt on
Old Jun 16, 2026 | 01:38 PM
OCSpringer's Avatar
OCSpringer
Curious why you're going to be in the high rpm range a lot without changes to the cams. You might want to go dig around on Hammer Performances website as there is more to it than just changing pistons/jugs and they have tons of good info on the subject. If I was doing this upgrade I would definitely be putting in cams as well while I had the top end apart. You don't need to get crazy with it to get some good results. It might be worth a call to Hammer as well.
Old Jun 16, 2026 | 02:33 PM
Paintslinger16's Avatar
Paintslinger16
Active Streak: 120 Days
While you are enlarging the space creating the 1200cc, you have did no other modifications to even increase your chance of hitting anything valve train wise. You also won’t be able to hit any higher RPM without raising that in a programmable ignition system.
With that said, if you are buying the proper kit it’s designed for stock 883 heads.
Everything works in harmony the carb will need a rework, to give you a bit more fuel.
I think you know this leaves a lot performance on the table, compression ratio, head flow, cams choices.
The higher RPM you seem to want will be unlocked by doing all of it.
Old Jun 17, 2026 | 06:43 AM
Bubba Zanetti's Avatar
Bubba Zanetti
Why not upgrade the cam while the motor is apart?
rbeauv1
Jan 20, 2024 04:48 PM
96SportyCustom
Jun 25, 2015 12:36 PM
FxTaz
Apr 9, 2012 12:27 PM
HocusFocus
Exhaust System Topics
Jan 31, 2008 09:20 AM
pauled
Mar 1, 2005 01:39 AM
