Need advice...Safe to ride with Fuel Moto canned tune for 124” big bore while waiting a month for dyno tune?
I’ve heard great things about the tuner (Those Dyno Guys), but based on the website scheduler, they don’t have any openings for another month (and I haven’t been able to get them on the phone or get a response to this question through website “Contact Us” or text message). I’ve heard FM gets close with their tunes, but that it still doesn’t compare to a Dyno Tune.
So here are a couple questions I hope those with more knowledge/experience can help with… 1) Is it safe to ride the bike on an FM canned tune for a month? 2) If not safe and I don’t want to let my bike sit for a month waiting to trailer it up to Those Dyno Guys, would a Power Vision Target Tune w O2 sensors ensure engine preservation, even if I ultimately need to get it dyno tuned for better fuel efficiency and performance?
After I completed the engine assembly, and installed the tune that Jamie sent me, I ran it, performed the heat cycles, and did some short-ish rides, and sent Jamie the log files. He tweaked it once, and I dumped the new tune in.
My plan was to ride the 1800+ miles to Wisconsin, and have Jamie dyno tune the bike, 2 months later. This was part of a longer 3 week excursion.
I rode it to work and back a half dozen times, pulled the tank, pulled the plugs and borescoped both cylinders. Looked perfect. Put in new plugs and rode it to Wisconsin without issue.
The dyno tune pulled it all together. I love it.
I AM NOT SAYING YOU SHOULD DO THIS. This is just my story, and you should just check with Fuel Moto.
Yes, I would trust a FuelMoto canned tune. I have their FM Street Outlaw (124" S&S crate engine) installed in my bike and dyno tuned by Jaime. He has tuned many 124" combos. I would not hesitate to use a canned tune FM sent you for one of their packages. I suspect it would be good to run as a final tune on a street driven bike, but I agree that anything over bolt-in cam should be dyno tuned...
FuelMoto tune note: I have also used several FM canned tunes for everything from OEM improved, to bolt-in cam configurations. After flashing the tunes, I have run auto tune sessions with both the Basic AT, and I also have a Pro AT module (uses wide band O2 sensors) for Pro AT sessions. Rarely do I need two AT sessions. I have run a couple with the AT Pro, got aggressive with the tune MAP areas I tried to hit, and only had a cells learned average of 1%.... That's a pretty good canned tune.
The Target tune uses wide band O2 sensors, and allows for a complete Closed Loop tune MAP.... but it will just use the sensors to keep the tune AFR matched with the AFR in the tune that is in ECM over varying conditions and loads.
Unless that ECM tune MAP is specific for your engine mods, it won't help you. Your 124" kit will undoubtedly need both AFR changes and timing changes from any previous MAP you have run.
If the ECM tune MAP is for your mods, from a good tune shop (like the FM tune you got) unless you are riding it like you stole it, IMHO, I see no advantage to the Target Tune. You'll be fine until the dyno session.
Good luck with your mods....
) , and the logs I sent back to Jamie were after 3 AT sessions. As you noted, not much change in AFR after the first one (at temp, 20 mile run)Trending Topics
I’m in the southern most end of Sarasota County so let me know if you want to give it a try.
