2008 front wheel swap question
Old Jun 20, 2026 | 12:46 PM
sjones73's Avatar
sjones73
Default 2008 front wheel swap question
Ok people. I am looking at purchasing a 2009 Road glide CVO 18" front rim and tire with brake rotors. This to replace my stock 16" front rim and tire.
I do not have ABS and am not sure if the CVO does or does not have abs bearings. So, going to change out the bearing no matter what.
I would like to swap this onto my 2008 ultra classic.
I have done some researching and can't find a 100% if it will fit and what needs to be changed if anything. I can find many older bikes that have had this done, but not the 08 ultra.
Seems as though the 08 models of my bike are a little different. Old and new parts mixed.
Can someone help me and tell what all needs to be done.
Thank you
Old Jun 20, 2026 | 07:52 PM
Max Headflow's Avatar
Max Headflow
It will fit but you may need to respace the wheel. Possibly use the spacers from a non ABS 09 wheel. The fork lowers are the same. I've installed like and 09-up 18 in street glide airstrike wheels on both a 07 egc and 02 rkc. but really don't remember what I had to do to get them to work.. The critical thing is that disk rotors don't need spacing.
@multihdrdr knows the details for most wheel changes. This will ping him.
Old Jun 20, 2026 | 10:36 PM
multihdrdr's Avatar
multihdrdr
The 2009 wheel with Std 25mm bearings (i.e. non ABS bearings) is a direct swap for your 2008.
Old Yesterday | 09:52 AM
sjones73's Avatar
sjones73
Multi.... Thank you for your reply.
So, I can use my axle and spacers correct? I ask because I will not have the CVO axle and spacers
Old Yesterday | 10:25 AM
multihdrdr's Avatar
multihdrdr
Correct
Make sure you install the first new bearing on the Left side of the wheel. That would be after determining which is the Left side of a wheel, but those CVO wheels have a directional curve to the spokes, so that should be easy
Old Yesterday | 01:32 PM
sjones73's Avatar
sjones73
Thank you
Thumbbagger
Oct 13, 2016 09:19 AM
tflatgard135@hotmail.com
Oct 12, 2016 09:50 PM
Magnut1
2014-2024 Touring Models
Jun 26, 2015 10:34 AM
2 Evil
Sep 18, 2014 11:44 PM
berniemc
Sep 17, 2011 03:53 PM
