Fuel question
Old Nov 11, 2014 | 04:20 PM
JonGolden's Avatar
JonGolden
Default Fuel question
Should I put in super 93 octane, that has ethanol, or 87 octane without ethanol? Those are my two options. I have an 04 FLST.
Thanks.
Old Nov 11, 2014 | 04:46 PM
Wide_Open's Avatar
Wide_Open
Go with the 93. If you are worried about the ethanol use something like Stabil 360 for ethanol.
Old Nov 11, 2014 | 04:49 PM
dfwhockey17's Avatar
dfwhockey17
93 octane. There are a bunch of additives out there now to help with ethanol problems, I run the Amsoil stuff myself...
Old Nov 12, 2014 | 03:19 PM
ChickinOnaChain's Avatar
ChickinOnaChain
Big Kahuna HDF Member
I used to use premium but over a year ago, I switched to regular. I haven't seen, heard or noticed any problems with performance.
As for ethanol, I've never seen a station that didn't have it.
Old Nov 12, 2014 | 03:24 PM
gerjets's Avatar
gerjets
Agreed. Go with the 93.
Old Nov 12, 2014 | 04:01 PM
olongapo1's Avatar
olongapo1
Unless you have a high compression engine there is no need to run high octane fuel. Ethanol fuel, in addition to having a short shelf life, also burns hot adding to engine temperature. Experiment with different octane ratings. If you find no performance differences, run the Non-Ethanol.
Old Nov 12, 2014 | 10:44 PM
bill in okc's Avatar
bill in okc
Not to mention the acetic acid produced by bacteria in ethanol/water that will corrode lots of stuff. Think filling your tank with acidic fuel.
Even the EPA now says that ethanol can destroy engines and void warranties.
http://www.americanmotorcyclist.com/...s_engines.aspx
http://www.epa.gov/ordntrnt/ORD/NRMR...-stp-sumps.pdf
Old Nov 13, 2014 | 05:52 AM
Warp Factor's Avatar
Warp Factor
Lots of myths about ethanol. Ethanol actually burns cooler than gasoline. Corrosion hasn't turned out to be the problem people thought it would be, even when putting E-85 in older fuel tanks (they convert to E-85 on some high-performance vehicles because it makes a good "race gas".... it's higher octane and burns cooler, isn't as toxic as leaded gas, and is easier to get).
Premium gas in Michigan has contained ethanol for at least 20 years now, and there haven't really been problems with it. Yes, it will run slightly leaner on older engines without oxygen sensors, which can't self-adjust to get the slightly richer ideal mixture.
Storage? People put vehicles up for the winter all the time in Michigan with E-10 in the tank, with no problems in the spring.
Running "regular" gas? Sure, it will work, but it takes away some of the safety margin against detonation, a major engine destroyer. And when the engine management system senses detonation (and it will do this before you can hear it), it will pull timing, costing some power and fuel economy.
I've had the same tankful of E-10 in in my standby generator for two years now, and there is no fuel or water separation, and nothing else strange going on.
Old Nov 13, 2014 | 06:13 AM
cocky's Avatar
cocky
Ive been using Lucas additive from wally world. No problems here.
Old Nov 13, 2014 | 08:18 AM
Smokey Stover's Avatar
Smokey Stover
Try www.pure-gas.org for a listing of stations that sell non-E.
