tombstone tail light on a stock heritage fender
I found these three setups (part #'s) on J&P's website:
3400640
3400520
3400521 (LED version of 3400520)
All of them require relocation of the turn signals, as it says it will not fit with the fender mounted turn signal bar.
According to their "fitment" guide, any of the three will fit the 2012 Heritage. Keep in mind, there is drilling involved. I liked the way it turned out on my Train's Fatboy fender, though.
Rear Wide Tomsbstone tail light with standard NT strut-mounted turn signals. Also used Laydown license plate bracket (but had to mount approximately 1/2" higher due to the Tombstone kit). I used small black plastic hole plugs to fill the factory license plate mounting holes.
After powdercoat
That there, sir.. Would be what the people native to my area call "snow".. It has been known to consume cars, homes, pets, even school districts. Personally, for me it is just another day!
No problem, man. Anything to help. One thing to consider on the Fat Lo, since they have a wider fender than the earlier (pre '06) Fatboys... Make sure the tail light opening is the same/similar. I've taken the liberty to look at the fender on eBay, and it looks like the tail light is probably the same, BUT, there appears to be a molding/stamped area of recession that surrounds where the tail light goes. You would probably see the recessed area but the tombstone would cover the actual hole.. Maybe a bit of body filler and some paint if you are feeling adventurous enough...
Received 3,963 Likes
__________________
Kevin
Gear Up & Ride in! DK Custom 4th Annual Open House, June 8th. 🏍️ Click HERE For The Lowdown.
DKCustomProducts.com
Kevin
The following 3 users liked this post by DK Custom:
