Do I need a Load Equalizer???
Old Jan 18, 2015 | 10:10 AM
joshso's Avatar
joshso
6th Gear
Default Do I need a Load Equalizer???
I'm going to swap out my stock (2010 Fatboy Lo) rear light and turn signals for the Genesis 2 LED tail light. Every site I see this on says that I "may" need a load equalizer...of course J&P says "yes you do"; but all the reviews I've read make no mention of this.
Has anyone installed this light and is this part necessary? I can't find any reference on here about the load equalizer either.
Old Jan 18, 2015 | 01:11 PM
Otter's Avatar
Otter
You do not. Just install the led’s and if your flashers are fast, turn the key on and then I think the procedure is something like turn on your left turn signal let it flash for 30 second, then the right, then back to the left. Do a search, it is listed here somewhere. Worked for me, and I have led’s all around.
Old Jan 18, 2015 | 03:43 PM
joshso's Avatar
joshso
6th Gear
Awesome...thanks for the info. You just saved me about $100!
Old Jan 18, 2015 | 10:22 PM
jam436's Avatar
jam436
The "hack" I got from Custom Dynamics for re-synchronizing the flash rates between the lights and the dash was to just run the four-ways for 2 or 3 minutes.
Old Jul 1, 2019 | 09:28 PM
Todd Kingery's Avatar
Todd Kingery
Stage II
Default Fatboy lo
So I was wondering how the install and light worked out for you. I just got my 10 fatboy lo and was looking to do the same thing. I was trying to see if I needed a equalizer also? Figured I’d ask how yours turned out and if it all works good?
Old Jul 1, 2019 | 09:35 PM
OldMike's Avatar
OldMike
OP has not posted since 2015.
Old Jul 1, 2019 | 09:44 PM
nascarfan's Avatar
nascarfan
I needed a load equalizer when I went with Custom Dynamics LED turn signals on my 2010 Fatboy.
I believe 2010 was the last year a load equalizer was needed on the Softails as the MOCO went to a Canbus system in 2011 for the Softail line.
Old Jul 1, 2019 | 10:30 PM
Todd Kingery
Stage II
Ok thanks good to know. I have a Sunpie all in one tail light I’m trying to put on but I don’t want to damage anything I’m doing it. I'll have to run to the dealer tomorrow and pick up an EQ
Old Jul 2, 2019 | 02:38 PM
Custom Dynamics's Avatar
Custom Dynamics
Former Sponsor
@nascarfan is 100% correct. If you are removing the stock turn signals or replacing them with LED signals on a 2010 or earlier Softail, you will need an equalizer or Smart Signal Stabilizer.
motogpfan82
Electrical/Lighting/Alarm
Jun 25, 2019 02:51 PM
Dean L
Jan 3, 2013 12:07 PM
Dean L
Dec 31, 2012 02:36 PM
Danny D
Mar 1, 2009 12:15 PM
Bigbird
Dec 20, 2006 02:32 PM
