Fluid change
Old Apr 14, 2015 | 06:01 PM
Cstrock's Avatar
Cstrock
2nd Gear
Default Fluid change
I am about to change all fluids in my 2000 fatboy. Question. I ordered oil filter and replacement o-rings for the oil drain plug. Will these also fit on the primary and trans. Drain plugs
Old Apr 14, 2015 | 06:04 PM
Kojax's Avatar
Kojax
Smile
they are all the same
Old Apr 14, 2015 | 06:07 PM
Tampa Fatboy's Avatar
Tampa Fatboy
First thing I do when I purchase a scoot > BTFSM > Buy the friggin service manual.
Anything else beforehand is just a waste of time and money .
Old Apr 14, 2015 | 07:35 PM
dfwhockey17's Avatar
dfwhockey17
Your engine and tranny drain plugs will be the same. Your primary drain plug is smaller in diameter and will not use the same oring. One thing I would recommend doing is using teflon tape on your drain plugs, and DO NOT over torque them...
Old Apr 14, 2015 | 07:49 PM
nikonf8's Avatar
nikonf8
Ten years changing my oil every 1000 miles never used any thing on the drain nuts nor did harley from the factory it's really not nessary also not nessary to change the o ring every change inspect and if not damaged its ok.
Old Apr 14, 2015 | 07:54 PM
Tampa Fatboy
Default nikon
Most important thng is the service manual, rtfm, pay attention to the torque specs and you might be alright.
Dood, I grab half a dozen 'O' rings when I hit HD. They sit in a lil baggy thng on the nail above the filters and fluids. I also have a friggin lil wood measuring stick I cut down, I'll let you figure out what that's for >lmbo
Folks that cut corners usually have problems that could have been caught early on.
Old Apr 14, 2015 | 08:11 PM
nikonf8's Avatar
nikonf8
Default Fluids
I also have extra o rings but it really isn't nessary you can do a visual and tell if the o ring is bad. To each his own as far as the stick I can only imagine what that is for
Old Apr 15, 2015 | 02:49 AM
Tampa Fatboy
I agree to a point, but I wouldn't share that thought with someone who didn't have the proper skills for fear they would develop bad habits. I probably should have left this topic alone, I can see where it could be misconstrued or seem a bit rude.
Old Apr 15, 2015 | 08:16 AM
tbonetony06's Avatar
tbonetony06
Im with nikonf8. I change my oil every 1000 miles, never go above 1500 miles. I replace all 3 o rings on every fluid change. Is it excessive? Probably! I have to much in this motor and it's very cheap insurance.
Old Apr 15, 2015 | 08:44 AM
Tampa Fatboy
Nikon said he didn't replace them if they weren't damaged. I suggested they be replaced regardless, even suggested the service manual be a first purchase for the new owner, especially for the torque specs.
Maybe I misread something, or misunderstood what I was reading, that's always a possibility...heheh
