What is this connection called?
Old 06-07-2015, 10:06 PM
sincitychoppa's Avatar
sincitychoppa
sincitychoppa is offline
Default What is this connection called?
What type of connector is this. There is a port on my bike that has female ports and they suply power when the bike is ON. I am looking to get a cable that this on one end and a USB on the other.
Old 06-07-2015, 10:10 PM
Bestrafen's Avatar
Bestrafen
Bestrafen is offline
Deutsch connector.
Old 06-07-2015, 10:44 PM
Krustee's Avatar
Krustee
Krustee is offline
That is a 12 volt power connection. USB connections are 5 volts. If you had a cord that went directly from 12 volt to USB you would most likely fry whatever you plugged into.
Dan
Old 06-07-2015, 11:25 PM
sincitychoppa
Dan
This product claims to be able to be used on all smart phones and tablets. It charges at 2.1 amps. Is there something I'm missing, would this product be safe?
Old 06-08-2015, 12:14 AM
Krustee's Avatar
Krustee
Krustee is offline
What product are you talking about?
Dan
Old 06-08-2015, 12:56 AM
sincitychoppa
Dan
oops forgot to paste the link: https://www.3brpowersports.com/products.php
however this is a square shaped Deutsch connectors where as the one I pictured above is almost half as tall and is a rectangular shape with 3 pins instead of 4.
Old 06-08-2015, 06:33 AM
Misbehaven's Avatar
Misbehaven
Misbehaven is offline
If you have a battery tender hook up for your bike same some time and money and use one of these.
Amazon.com: Battery Tender 081-0158 Black Quick Disconnect Plug with USB Charger: Automotive Amazon.com: Battery Tender 081-0158 Black Quick Disconnect Plug with USB Charger: Automotive
It works with my Iphone 5,Kindle,Motorola Droid Turbo and all other usb devices I have tried.
Old 06-08-2015, 10:28 AM
Krustee's Avatar
Krustee
Krustee is offline
Old 06-08-2015, 07:11 PM
sincitychoppa
Thanks
Romley
09-05-2016 07:53 PM
Cull22420
03-01-2016 07:09 PM
azbob09
2014-2023 Touring Models
04-06-2015 06:55 PM
iamtylerdurden
09-03-2013 07:17 PM
Chopperbob
04-12-2013 11:42 AM
Quick Reply: What is this connection called?
