speedometer inop. options? 2005 springer classic
about a mile into starting a ride yesterday i noticed my speedometer wasn't working. from what i've read so far it may be the speedo it's self (turn signals still cancel, odo still working, various warning lights still working). haven't had it back out to see (i prettymuch to rode back home and parked it) beyond checking the plugs under the console, the fuse, and a roll down the drive to see if either made a difference.
still trying to troubleshoot, but if i have to change it, can i get one with the tach at the bottom or in the corner? i see them on ebay and had been wanting one anyway, but don't know what may or may not interchange.
thanks for any help on either question.
edit: in case it makes a difference, it's fuel injected.
The HD Combo Speedo/Tach is a great upgrade.
https://www.surdyke.com/AdvPartInfo....mber=70900071A
$276.65
http://www.harley-davidson.com/store...og-speedo-tach
http://www.harley-davidson.com/store...cted=category2
$276.65
thanks, but crisis averted for now.
my supervisor rode in to work yesterday and pointed out the sensor I needed to be looking at (I was looking at the wrong one). just pull it out and wipe off the metal shavings he said. I didn't think it would work since it didn't seem to have any, but I stuck back in and the speedo worked fine.
i'd still like a speedo tach, but can go back to searching at my leisure (and hoping to luck on a deal). also still wondering if there's a way to know what will interchange. thanks again.
$276.65
$276.65
Those speedos marry to the computer on the bike after 30 miles or so and then cannot be married to another bike. HD won't do it. This is for 04+, bikes earlier bikes had the miles stored in the speedometer.
So don't buy one used unless you want to use it as a paperweight.
Oh and while I have one, and I think it looks cool, the tach is way too far out of your line of site to be useful when running through the gears. You don't want to be looking down when you have the throttle WOT. A bar mount that you can see out of your peripheral vision is much better for a usable tach if you really want a tach to use it to wind out the gears.
I had the same problem with my 03 bike speedo by the way, with the same solution.
still want one eventually though. i just like having one for more the opposite reason than racing. i tend to putter around on the low end of useable rpm's, and don't want to lug too much.
still ebaying for styles and see one i like (can't post a link but one part# is 74723-10), but the earliest year i've seen it for is 2008. this one says '09-'11. anyone know if that will work on my 2005? thanks.
