Kuryakyn Phase 7 Headlight ?
Old Jul 17, 2015 | 08:48 AM
wiktor's Avatar
wiktor
Default Kuryakyn Phase 7 Headlight ?
I have a 2011 Fatboy and would like to upgrade the lighting. The Kuryakyn headlight seems to be the best deal on an LED light. I have heard there are issues with my bike due to the low current draw. Has anyone experienced this and how do you like the light? Thanks for any help!
Old Jul 17, 2015 | 09:19 AM
Prot's Avatar
Prot
http://www.drivetrainamerica.com/tru...gler-cj-tj-jk/
That's the best deal out there. They also have a kit if you have the auxillary lights like a Heritage.
Old Jul 17, 2015 | 09:31 AM
wiktor's Avatar
wiktor
Thanks for the reply! I do have auxiliary lights as well. Any issues with the low current draw?
Old Jul 17, 2015 | 10:03 AM
Prot's Avatar
Prot
I have the three piece kit on my 95 Heritage and works great. The low current draw is a bonus because that leaves more power available to the starter when cranking this old beast up.
You have to deal with issues of low current draw / light load / low resistance when you start fooling with turn signals. I went with custom dynamics flat plate inserts on my turn signals, fender tips, and tail / brake lights.
The headlight sticks out further than stock and looks goofy, but that is easily taken care of with a frenched in trim ring.
Old Jul 17, 2015 | 10:46 AM
Prot's Avatar
Prot
Here is a link for the three piece kit.
http://www.drivetrainamerica.com/tru...5-pass-lights/
Old Jul 17, 2015 | 12:08 PM
Misbehaven's Avatar
Misbehaven
I run the phase 7 light on my 2011 Fatboy Lo with out any issues. No codes and no need for a load equalizer.
Old Jul 17, 2015 | 06:55 PM
fattyboyrider's Avatar
fattyboyrider
I have a 03 Fatboy has anyone have the headwinds headlight ? Will it work on my bike ?
Old Jul 17, 2015 | 07:11 PM
Prot's Avatar
Prot
Can you post a link to the specific headlight, as headwinds makes more headlights than I can count.
Old Jul 17, 2015 | 07:34 PM
fattyboyrider
Headwinds 7 in led part #164-261.j&pcycles.com/harley-parts $264 has low 500 lumens, high beam 1100 lumens. Mfg part #89751. Suppose to be able to plug into stock connector.
Old Jul 17, 2015 | 07:44 PM
fattyboyrider
Headwinds 7″ LED Headlamp
• Easy-to-install
• High/low beam
• 500 lumens low, 1100 lumens high
• 12-24V DC
• 1.7 amps low, 2.6 amps high @ 12.8V DC
• Plugs into stock 9003 headlight connector
• Long-lasting and rugged, solid state LEDs withstand shock and vibration
• Die-cast aluminum housing with cooling fins to provide maximum protection
