Speedometer/odometer not working
Old Aug 16, 2015 | 03:46 PM
Springerstar's Avatar
Springerstar
Stage III
Default Speedometer/odometer not working
I have an 06 Springer and the speedometer and odometer display stopped working. When I press the odometer display it comes on temporarily then goes off after 3-4 seconds. I checked the fuses and the grounds around the battery and everything looks fine. Any suggestions?
Thanks
Old Aug 16, 2015 | 04:12 PM
jtarter's Avatar
jtarter
Check your connections under the dash/speedo
Old Apr 8, 2019 | 02:46 PM
Michael Radigan's Avatar
Michael Radigan
Stage II
I’m having the exact same issue. Did you ever figure it out?
Old Apr 8, 2019 | 09:45 PM
jtarter's Avatar
jtarter
You might have better luck using the search function or starting a new thread with your own question as this post is almost 4 years old and the OP hasn't been on here since then.
Springerstar
Electrical/Lighting/Alarm
Aug 16, 2015 11:30 PM
Springerstar
Aug 13, 2015 04:27 AM
venomv8
Jun 15, 2014 07:10 AM
venomv8
Apr 23, 2014 01:35 PM
kengardner
Jun 30, 2012 08:06 AM
