Big city thunder baffles re-tuning
Fitted baffles today in big radius pipes as per the recommended position by BCTB. 6" from the end. That was easy - not. I started it up and tbh it didn't sound much different to the stock V & A std baffles. But to be fair it was in the garage so very echoey. Anyway now I have, technically, a different system, does the mapping need to be changed? I plugged my FP3 in and for my pipes it just said std baffle or none. Not ridden it yet as it was raining today.
Does anyone know?
Thanks
Does anyone know?
Thanks
I would autotune every time I made a change to the airflow. Changing baffles, cleaning out or replacing the filter, even changing an air cleaner cover. Why wouldn't you try and get the best out of your bike, since you already have all the equipment to do so? In the time it takes you to read all the posts that your thread attracts, you could be out riding the thing. There's still good weather in the UK. Make the most of it!
I used to run that same set up plus I installed the shortened stock V&H baffle after the BCT baffles near the pipe exit. The biggest and best thing to dial the sound tone/note in was to adjust the V&H FuelPak I had previously installed.
Cheers
Cheers
Cheers
Cheers
The older one. 2003 Softail. Took a lot of the pingy tone away and gave it a more mild throaty sound. I had to play with the first few numbers on the FuelPak to remove the throttle stutter off the bottom.
JonW
Exhaust System Topics
Oct 26, 2011 05:37 AM
AdrianVall
Feb 23, 2008 09:15 AM
