Handle bar wire connection, repon solder or connector?
I understand that wire extensions go between the factory wire and where it connects under the tank.
But i see people using words like splice and repin.
So it unclear to me what happens at the hand controls. Is there soldering or repinning required there or is it a connector?
2014 Slim
Thanks
2014 Slim
Thanks
Soldered in there I believe. I have a loose hot wire in mine which I was able to slide up and just gorilla glued the part where the wire sheath slides in. It appears you can open the housing where it slides in and I presume re-solder it to the board, but after a week of just wanting to be done with my own wiring, the glue fixed worked for now. I can readdress it later if I get a wile hair.
I was thinking my stock wiring was internal in the bars but it actually is not. Internal is what it will be in the new bars.
Trying to picture what end of the harness feeds in first?
