3" FWD ext on Breakout
Old 07-15-2016, 05:31 PM
JTAC's Avatar
JTAC
JTAC is offline
Default 3" FWD ext on Breakout
Need some help from those that have done this. Currently have the right side off. How did you access the banjo bolt for the rear caliper? That bad boy is hidden like hell. Did you guys remove the rear wheel??
The light is shining on the brake line (lower one) coming from the old line that I'm replacing with the new one.
JTAC's Avatar
JTAC
JTAC is offline
Forgot to say it's on a 2014 BO with ABS
Old 07-15-2016, 05:52 PM
Dalt10's Avatar
Dalt10
Dalt10 is offline
It's a pain in the butt. I took the back fender off and the exhaust. Pulled the plastic fender up. It was still hard to get to it. I did it on both my Breakouts. Instead of explaining it go to this thread. Read thru the whole thread.
https://www.hdforums.com/forum/softa...-breakout.html
Old 07-15-2016, 07:39 PM
JTAC's Avatar
JTAC
JTAC is offline
That's what I've done. Got the banjo off. Getting it back on....that's a whole new ball game for those with big hands
Old 07-15-2016, 07:40 PM
JTAC's Avatar
JTAC
JTAC is offline
Old 07-15-2016, 08:14 PM
Rocker B's Avatar
Rocker B
Rocker B is offline
I had my wheel off when I did it...doesn't take long to take it off and put it back...
Old 07-15-2016, 09:48 PM
Dalt10's Avatar
Dalt10
Dalt10 is offline
I have big hands to and could barely get in there. Unless you take the wheel off the only thing I can tell you is you have to squeeze you hand in there with the brake line and the banjo bolt. It took me 4 or 5 times before I got the bolt started.
Old 07-15-2016, 10:23 PM
JTAC's Avatar
JTAC
JTAC is offline
What a nightmare that was. Didn't have to take off the tire, but that hand was tight....
Still haven't bled them...
Old 07-15-2016, 10:24 PM
JTAC's Avatar
JTAC
JTAC is offline
I was gonna do the sprocket at the same time, but it didn't come in...ill hold off
Old 07-15-2016, 10:46 PM
JTAC's Avatar
JTAC
JTAC is offline
Done for the night. Gonna do the left tmrw and bleed them to wrap it up and go for a ride.
Sitting on the bike level. You can see the difference from right to left. A couple of inches.
Quick Reply: 3" FWD ext on Breakout
