Winter Storage
Old Oct 17, 2016 | 09:56 AM
Swamp Donkey's Avatar
Swamp Donkey
6th Gear
Default Winter Storage
Hey guys and gals . Was curious as to what some people do to their bikes for winter storage. Unfortunately in Ohio it's hard to ride all year . Thanks .
Old Oct 17, 2016 | 10:31 AM
Berick's Avatar
Berick
Mine sits in my unheated garage all winter with a C-tek battery maintainer hooked up to it. I should probably throw fuel stabilizer in there too but I've never used the stuff in any of my seasonal equipment and I've never had a problem.
Old Oct 17, 2016 | 10:38 AM
EagleRay's Avatar
EagleRay
As I don't have any location to safely store the bike during winter I let my dealer take care of it. They charge me 2 bucks a day for storing the bike in a temperate and dust-free environment, covered up and insured. The battery will be kept on the tender. In spring they will do a brief check-up before delivering the bike.
Only 2 weeks left before bike goes into storage
Old Oct 17, 2016 | 10:49 AM
jam436's Avatar
jam436
I put mine in storage for the first time at the dealer last year around Thanksgiving.
I had it in for the 15K service and since the storage included an oil change, wash and detail, I told them to just keep it.
I'm sorry I did now.
Last winter was so mild here in PA that there were bikes going past my house nearly every week before that 2-week cold spell we had in February.
Usually I just top it off and throw in a can of Seafoam stabilizer, hook up the batter tender and rotate it one week on, one week off, all winter.
I even leave it set it up on the jack to keep it a couple of inches off the ground.
Throw a sheet over it to keep the dust off and you're good.
Probably a good idea to do an oil change before storage too.
Mine sits in a semi-heated attached garage.
Old Oct 17, 2016 | 11:06 AM
Kingface's Avatar
Kingface
I throw in some stabilizer, top it off with fuel, go for a 30 minute ride, top it off with more fuel. I then tuck the Fatboy in the same part of the garage that the snow blower resides in over the Summer and the snow blower takes the Fatboy's spot. It's a non heated attached garage, hook up the Battery Tender Jr. to it once a week for a day or so, put a queen size flat bed sheet over it and put plastic baggies wrapped with a rubber band over the exhaust tips to keep any unwanted little furry creatures from finding a home.
Some people keep there's on plywood or on a bike jack off the concrete as they say concrete makes the tires get a flat spot......but that's a load of crap. I used to change the oil at the end of each riding season too but I just found I was wasting money. So now I just do it according to the service schedule.
There's a ton of great info on this site so search away!
Old Oct 17, 2016 | 11:47 AM
jam436's Avatar
jam436
Originally Posted by Kingface
..and put plastic baggies wrapped with a rubber band over the exhaust tips to keep any unwanted little furry creatures from finding a home.
Yep, that too. - forgot about that.
Old Oct 17, 2016 | 12:14 PM
Ludwig von Buzzthoven's Avatar
This will be my first winter with the Softail. But for the past 2 years, I topped off the tank with gas, poured in some stabilizer, put the battery tender on it, then covered the bike. It started in the spring with no problems when I rolled it out of the garage. I'll do the same with the Softail.
I never put plastic bags on the exhaust tips. Is there any concerns about condensation building up in there and not being able to dry out?
Old Oct 17, 2016 | 12:24 PM
Kingface's Avatar
Kingface
I have heard that not doing the baggy thing actually will cause moisture build up which is another reason why I do it. You can also spray WD40, LPS3 or any Corrosion Protectant in the tips before you throw the baggie's on also.......but for some reason the makes me uncomfortable. I will say though that I'm in Maine.....in the Winter time the air is INSANELY dry and the temperature is always the same in the garage.......COLD! I never had an issue doing that but it could depend more on where you live. I you've never done it....then maybe keep not doing it to stay on the safe side! I just know by me that mice LOVE little holes to hide up in for a few months up by me.
Old Oct 17, 2016 | 04:57 PM
murray5p's Avatar
murray5p
Just put her to bed for the winter. Its sitting on my Big Blue Lift. She's going to get a good waxing and detailing over the winter.
Attached Thumbnails Winter Storage-img_1473.jpg   Winter Storage-img_1474.jpg   Winter Storage-img_1476.jpg   Winter Storage-img_1475.jpg   Winter Storage-img_1477.jpg
Old Oct 17, 2016 | 10:58 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Just use some steel wool to block the ends of the pipes. Mice can chew through plastic but the wool will stop them.
