Talk to me about Programming
Old May 31, 2007 | 03:34 PM
Crusher's Avatar
Crusher
Default Talk to me about Programming
2007 Deuce. V&H Big Shots w/quiet baffles and K&N filter. Suggestions on programming needed.
Old May 31, 2007 | 05:31 PM
Bowtieman31's Avatar
Bowtieman31
Default RE: Talk to me about Programming
This is a VERY broad subject. There are so many choices from the HD Stage 1 re-map, to all together different ECM's. You need to consider how many performance options you are going to add in the future and then pick a product that will be versitle enough to accommodate the changes. The HD Stage 1 is the easiest and cheapist. It is also very limited in what you can do with it. The Power Commander and the HD Race Tuner are two of the most versatile and will accommodate many changes. The best way to achieve maximum power from these is by Dyno-Tuning your bike. That can be costly.Then there are replacemant ECM's. Since I have no direct experience with those I will let someone else tell about them.
Old May 31, 2007 | 10:03 PM
Crusher's Avatar
Crusher
I'm not a performance guy when it comes to the Deuce. So these will most likely be the only performance upgrades.
cpudoc
Jun 11, 2018 07:48 AM
sloosky
May 27, 2014 05:10 PM
Kevinmach1
Jul 31, 2013 09:29 PM
hewes18red
Oct 12, 2010 05:03 PM
crossfire3006
Jun 28, 2007 02:38 PM
