Deluxe Mod Questions??
(1) What's the best after market air-cleaner....I don't want any big cone filters.
(2) What tuner?? - does the power commander have the ability to remap the FI similar to the screamin eagle component.... i.e does the Power commander have a basic (canned) stage 1 program?
(3) Can I add do a stage 1 remap while leaving the exhaust and aircleaner stock? This engine runs much hotter than the older deuce. As I understand the stage 1 basically richens up the fuel mix.
(4) If I do this work on my own, will this affect any future warranty claims?
Thanks...
2) There is no "best". Each tuner (SERT, PC, V&H, etc..) has it's own proponents and detractors, and it's own pros and cons. Doing a search here will find you so much data your head will end up spinning, and you won't walk away with a definitive "best". I went with a PC V because it's flexible, everyone uses them and can tune them (if I choose to change things later on, there are tons of canned maps available to try without a dyno tune). I purchased the aforementioned PC from FuelMoto, told them how my bike was setup (Air Cleaner and pipes, plus anything else) and it came pre-programmed with a tune that seems to work great. A plain PC does not come with a tune, you need to make one yourself or download one.
3) You can, but it's not worth the $$ IMHO, because you'll want to do it all over again when you do a AC and/or pipes.
4) Yup, it could. If they can prove that something you did caused the fault for which you are asking for warrantee service on. Some dealers use it as a general excuse, others don't.
I came from a Carb'ed Deuce to a Deluxe too. You won't regret the move!
Anyone have suggestions on a good place to purchase a power commander.....somewhere that has good customer support?? I assume the PC V is the way to go?
Fuel Moto. They are a sponsor here also.
I also like V&H pipes, except the fishtails by them.
For an Air cleaner it is really just what you like in looks. Here are my favorites, if I could afford them right now.
http://www.performancemachine.com/Ca...px?display=734
X
