ABS prob on a softail slim s with 21"
Old Jun 19, 2017 | 12:42 PM
Bagged Out's Avatar
Bagged Out
Default ABS prob on a softail slim s with 21"
Hey guys,
posting this for my buddy. He just bought a slightly used 2016 slim s with a 21 inch wheel on the front. The ABS light warning is blinking. He has had it reset and the stealer has tried to work on it.
The dealer is telling him that the largest tire you can put on this bike is a 19 inch and still have abs work. I went through this problem with my Street Glide Special with linked brakes but this doesn't have linked brakes.
Any input on this guy's? Is the dealer correct? Can anyone call B.S. on this based on experience? Bad *** bike!
Old Jun 19, 2017 | 12:50 PM
Otter's Avatar
Otter
http://www.baggersmag.com/thundermax...on-module-2015
Old Jun 19, 2017 | 06:44 PM
Bagged Out's Avatar
Bagged Out
Default ??
Thanks Otter,
this would have cured the problem with my linked brakes and ABS but not sure it fixes the softail ABS problem?
Old Jun 20, 2017 | 07:30 AM
Otter's Avatar
Otter
I bet it will, give them a call
Old Jun 30, 2017 | 01:11 PM
Bagged Out's Avatar
Bagged Out
Default C1021
so, the thundermax fixes code C1029. This slim is throwing code C1021 -
C1021 ABS front WSS always zero
does anyone else that has pit a 21" wheel on their slim s had this problem with their ABS?
could really use some input.
Old Jun 30, 2017 | 07:53 PM
Otter's Avatar
Otter
I have had this code, when I inadvertently left my abs sensor wire unplugged under the tank. You may have a broken wire in the sensor line, its a known issue, the moco zipties that wire too tight sometimes on the head tube and it can break the wire. You can also unbolt the tank front and rear, disconnect your fuel line and slide the tank back about four inches. Stuff microfiber towels underneath to keep from gouging the rocker box covers, particular attention to the pinch clamps for the fuel crossover. Check the grey two-wire connector on the left side of the top tube, under the rubber boot. I’m sure there's a resistance measurement for the WSS that you can probably google and find. Like I said, in my case it was just not fully connected the first time I powered the bike up to check my hand control wiring after extending it, you may find yours simply disconnected. Sounds to me, worst case, you either have to repair a broken wire, or replace the WSS, neither of which are incredibly complex repairs.
Hope that helps
Old Jun 30, 2017 | 10:39 PM
Otter's Avatar
Otter
Also, I wouldnt get discouraged becasue the dealer is dismissive, Often times they dont know their own products very well. Just concentrate on diagnosing the problem and forget what the dealer told you.
Old Jul 2, 2017 | 11:38 PM
Otter's Avatar
Otter
How did this turn out? (Asking for a friend)
Old Jun 27, 2019 | 07:37 PM
Scott Skully Viar's Avatar
Scott Skully Viar
Stage III
Gonna have to get this for my 2015 softail throwing code 1029 , Thanks for the heads up ! **** is driving me crazy!
Old Jun 28, 2019 | 09:05 AM
Spindrifter's Avatar
Spindrifter
I had the ABS light and code problem on my 2015 CVO Deluxe after putting a 21" wheel on the front. Talking to Sinister wheel, it required an Arlen Ness ABS bearing to solve the problem. Not sure what's different about that bearing but the problem went away.
