Ignition problems
Old Jul 2, 2017 | 12:03 PM
IBD12KNOW's Avatar
IBD12KNOW
Stage II
Default Ignition problems
'04 Softail Deuce, runs fine at idle and low rpm, once you get moving it will cut out and backfire. The strange thing is when it comes back. which is right away, the speedometer goes all the way to the max and then all the way back to zero and then will start to register speed again. Already replaced the voltage regulator, stator, and checked for good ground....any ideas?
Thanks
Old Jul 2, 2017 | 01:20 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Looks like you don`t BD12KNOW...
Old Jul 2, 2017 | 01:29 PM
QC's Avatar
QC
Ignition switch. Check under the dash at all the connections and clean the switch itself.
https://www.hdforums.com/forum/softa...le-riding.html
Old Jul 2, 2017 | 01:48 PM
Bone Doc's Avatar
Bone Doc
Thanks
Why did you replace the voltage regulator and stator before diagnosing the problem?
Old Jul 2, 2017 | 03:37 PM
IBD12KNOW's Avatar
IBD12KNOW
Stage II
Because that's what the stupid ****ing mechanics diagnosis was at the Harley shop and it didn't fix it!
drm1978
EVO
Jun 20, 2016 08:28 AM
harley_504
Touring Parts
Mar 21, 2010 05:58 PM
Seaweed1929
Dec 4, 2009 08:32 PM
oldsport
Aug 25, 2006 11:01 AM
machinst69
Dec 4, 2005 04:18 PM
