What year Fat boy 2005-2008?
Old 07-22-2017, 04:29 PM
Levy1's Avatar
Levy1
Levy1 is offline
Default What year Fat boy 2005-2008?
Love my v rod, 112HP/100 TORQUE. My 04 Fat Boy was 115/115. I am going to buy used and install a 107 from Hals HD. Will be around 125/125.Are there any big differences except the gear ratio change in 07.
Thanks
Old 07-23-2017, 03:22 PM
Levy1's Avatar
Levy1
Levy1 is offline
Ok, need suggestions on what year to buy.
Old 07-23-2017, 06:12 PM
95th 1200's Avatar
95th 1200
95th 1200 is offline
Any year will do, make sure you find one that's in good mechanical condition for the power you're going to be making. You can do pulley swaps to get more top end or bottom end power, that's no big deal. Make sure you talk to Dustin at Hal's, he's the main Speed Shop builder and tuner.
Old 07-23-2017, 06:19 PM
the blob's Avatar
the blob
the blob is offline
Don't know about gearing, but I like
The pre 07 style fat boys better.
Old 07-23-2017, 07:56 PM
Levy1's Avatar
Levy1
Levy1 is offline
Thank you, I am already set up with Dustin at Hals. I read about the ratio change on I believe 2007 and up to change the pulley and that's great advice. I am thinking I need to be into a 6-speed with all the mods I'm doing sounds like that'll make everything about perfect. What year does the 6-speed start? What year was the gear ratio change was that 07?
I am going to stay under ten thousand miles and hope to find one around 7000. I bought my V-Rod with 7000 and it rides like a new bike.
Old 07-23-2017, 08:42 PM
Dave0176's Avatar
Dave0176
Dave0176 is offline
Six speeds start in 07, unfortunately 07 they went to 66 tooth gearing, however that can easily be remedied, 07 also started the 200mm rear tire. 07s supposedly have weak cranks. 07 also started the 96 ci so to make a 107 just requires a simple cylinder bolt on.
Old 07-23-2017, 09:00 PM
Punjabi Rider's Avatar
Punjabi Rider
Punjabi Rider is offline
Not sure if it's the same for the softail but touring 6 speed ratio is lot better from 09 and up.
chunks
09-29-2021 12:38 AM
Timbo64
04-26-2020 12:55 PM
brutalbrad
01-01-2013 05:30 PM
drd21968
12-17-2007 02:25 PM
eagle56
09-30-2007 01:56 PM
Quick Reply: What year Fat boy 2005-2008?
