2006 Heritage Front & Rear Fender Light
2008 Heritage Front & Rear Fender Light
My front fender light stopped working so I figured the bulb burned out. I cracked the front lens as I couldn't find instructions here for removal.
Yes I am a dim wit and knew it was going to happen. The thing was in there tight and I always screw things up.... just search my posts here...
Ok, how do you remove it?
Put pressure with a screw driver on the top groove and twist, you are pulling down on top side tabs. Out it comes .
Next, I pulled the bulb and I replaced with:
Bulb # 194 Sylvania and used "Sure Connect Bulb Grease" Part No 15320. The Sylvania package had two bulbs so did the rear fender. The grease makes a good connection.
The hairline crack in the front lens is something no one would see, but its imprinted on my brain. I ordered a replacement on eBay, essentially doubling the cost off the repair.
I hope this helps someone.
