Front fender light.
Old Sep 5, 2014 | 08:12 AM
Hair53's Avatar
Hair53
Default Front fender light.
My front fender light stopped working so I figured the bulb burned out. I pulled the bulb and checked it with an ohm meter and it tested good so I put it back in the socked and it came on. I cleaned the bulb and socket fittings and it worked for a couple days and now it is off again, I pulled and placed the bulb back in and it worked about a day now it's off again. Has anyone ever had this issue and what was the fix? Hoping something simple before I start looking for the bad connection. TIA.
Old Sep 5, 2014 | 10:30 AM
Skeezmachine's Avatar
Skeezmachine
For what they cost, why not just replace the bulb to make sure that it in fact doesn't have a problem or defect?
I had a problem with my rear break light socket after it got overheated by the break light being stuck in the on position due to a bad flow switch. After that I had a problem with the connectors making good contact with those on the bulb because the socket had warped a bit from the heat. Maybe for some reason the connectors in your socket aren't making good contact with those on the bulb?
Old Sep 5, 2014 | 11:29 AM
Benway's Avatar
Benway
Gotta say I never checked if mine is even working :P
Old Sep 5, 2014 | 08:24 PM
oct1949's Avatar
oct1949
thinking its a bulb or wiring issue... check both
Old Sep 5, 2014 | 09:03 PM
Pitbull_Dallas's Avatar
Pitbull_Dallas
Put a new bulb in and see what happens. I had the same problem on the rear and it was the bulb. The element was fine, but there was a break in the contact wire just inside the glass. I did the exact same thing you did. It worked and then didn't work.
Old Sep 5, 2014 | 09:13 PM
Firemantaz22's Avatar
Firemantaz22
Absolutely try a new bulb first. If you have a volt meter that checks resistance or continuity I would perform the following. First, using your voltmeter, check the circuit that has voltage to it in the lamp socket and verify you have voltage. If not, I would say you have a problem in that circuit. If you do have voltage then check for continuity in the ground side of the lamp socket. Whichever circuit is causing the problem you will need to trace it out.
Old Sep 5, 2014 | 10:03 PM
Hair53's Avatar
Hair53
I was going to replace the bulb when I had it to the dealer for the 5.000 mile service, they didn't have the bulb in stock. lol. I will look elsewhere for a bulb. Thanks for the replies.
Old Sep 6, 2014 | 06:54 AM
Pitbull_Dallas
You can get the bulb at any auto parts store.
Old Sep 6, 2014 | 07:17 AM
Hair53's Avatar
Hair53
I thought so. Thnx.
Old Sep 6, 2014 | 05:26 PM
Mr HOG's Avatar
Mr HOG
Could be the bulb and/or corrosion on the socket. I always use dielectric grease on all connections.
Daniel Longtin
Apr 26, 2019 11:05 AM
a99miata
Apr 23, 2014 10:39 PM
Z06_Pilot
Aug 15, 2010 12:30 AM
clenaghen
Jun 27, 2010 11:39 PM
kaptekarev
Panhead
May 19, 2007 03:22 AM
