Single Fire or Dual Fire?
Old Sep 9, 2017 | 06:15 PM
stang89's Avatar
stang89
Stage III
Default Single Fire or Dual Fire?
Hey guys I have a 2009 Fatboy, I just bought a autometer procycle rpm gauge and I can't seem to find where to connect my rpm signal wire to. Is the bike a single or dual fire ignition? The coil has 4 wire I can't seem to find which one is gound? Has anyone installed one of these gauges on there bikes? Thanks!
Old Sep 10, 2017 | 05:44 AM
stang89's Avatar
stang89
Stage III
Anyone?
Old Sep 10, 2017 | 06:05 AM
badcooky's Avatar
badcooky
Most probably will be a dual fire, run the numbers on the coil to a google search and you should find it and that'll probably give you the earth/ground post too if not run the same unit for a schematic/electrical diagram.
HTH
Old Sep 10, 2017 | 06:53 AM
stang89's Avatar
stang89
Stage III
So i found that its a single fire, checked the wire diagram and these are the 4 wires to the coil. It says connect the wire from the rpm to gound on the coil?
A- Power
B- Ion Sence
C-Coil Rear
D- Coil Front
Old Sep 10, 2017 | 07:27 AM
badcooky's Avatar
badcooky
It's probably the "B" post but b4 you wire in to it make sure that the B posts wire is a grounded wire so that it either goes to the negative battery terminal or goes to an earth on the bike somewhere. If it doesn't it's not the one you want but it should be..
joker77535
Jul 5, 2013 11:27 AM
run_ride_hide
Dec 22, 2012 05:06 PM
tymatt67
Sep 23, 2012 08:54 AM
rbrapp1
Panhead
Oct 17, 2010 12:13 AM
dts
Aug 17, 2007 06:15 PM
