strange oil leak
Old 08-11-2018, 08:08 AM
jjohn's Avatar
jjohn
jjohn is offline
6th Gear
Default strange oil leak
I recently bought a 93 fatboy that hasnt been ridden in a while. after riding it one day I parked it and the next morning I noticed an oil leak I looked under the bike. couldnt really tell where it was coming from so I fired it up and began to inspect I began to notice oil coming from around a bolt located next to the oil filter I tjought it was coming from around the filter itself. any help would be appreciated
Old 08-11-2018, 08:15 AM
gdishman's Avatar
gdishman
gdishman is offline
Clean the area real good. Use brake cleaner to dry the area. You can use baby power and spread it around the area. Fire up the bike and the power will show wear the leak or seep is coming from. Next step would be putting dye in the oil. Are you sure the oil filer is not leaking?
QC's Avatar
QC
QC is offline
Received 19,786 Likes on 9,863 Posts
Pictures would help.
Clean the area, start the bike and see if you can actually see where the oil is coming from.
jjohn's Avatar
jjohn
jjohn is offline
6th Gear
the culprit
Old 08-11-2018, 08:17 AM
jjohn's Avatar
jjohn
jjohn is offline
6th Gear
when I started the bike I looked underneath with a light and you could see it coming from around that bolt
Old 08-11-2018, 09:22 AM
Uncle G.'s Avatar
Uncle G.
Uncle G. is offline
Received 3,704 Likes on 1,989 Posts
that's the motor mount bolt. What oil I see looks like spillage from a previous oil filter change that nobody cleaned up. I'd thoroughly clean that area and keep an eye on it.
Old 08-11-2018, 10:02 AM
jjohn's Avatar
jjohn
jjohn is offline
6th Gear
so it could be coming from the filter and seeping around the bolt ?
Old 08-11-2018, 10:32 AM
aviscomi's Avatar
aviscomi
aviscomi is offline
The bike is kinda old and sitting for a while, with that said I assume you have at least changed all the fluids prior to riding it.
HDLO
10-31-2022 11:50 AM
Buns79
02-28-2016 07:57 AM
paulhog
09-19-2010 07:49 PM
daharleyrdr
01-11-2009 07:41 AM
LiLCricket
09-23-2007 02:23 PM
Quick Reply: strange oil leak
