how to fit the biggest tire on a 2002 train
Old 10-17-2018, 09:04 AM
dkapp0802's Avatar
dkapp0802
dkapp0802 is offline
Stage I
Default how to fit the biggest tire on a 2002 train
i have a 2002 night train that i am wanting to put a wider tire on. i read that you can put a 150 on it but im wanting more in the neighborhood of mid 200s. now obviously id have to widen the swing arm but what about the final drive? would i have to space the front belt drive?
Old 10-17-2018, 09:29 AM
Tom84FXST's Avatar
Tom84FXST
Tom84FXST is offline
Received 18,392 Likes on 5,440 Posts
There is no cheap way to get into the mid 200's. You need to buy a wide tire kit from a reputable company...their are Chinese copy wide tire kits...
but on a 2000-up Softail you have to space out the primary, and use an extended main-shaft in the trans...don't want any Chinese parts in there.
https://heartlandbiker.com/collectio...-cam-2000-2006
https://www.performancemachine.com/m...atail-kit.aspx
The fat tire craze is over, so you may be able to find a deal on one of the above kits...as several vendors sell both of the above.
Old 10-17-2018, 02:58 PM
TUFF LUCK's Avatar
TUFF LUCK
TUFF LUCK is offline
Like Tom said if you ar going to do it stick with a well known company, heartland would be my choice..
Agree'd with that wide tire craze, but I think a 200mm is a pretty tasteful tire for softails, but thats only my opinion.
Old 10-17-2018, 03:44 PM
donk_316's Avatar
donk_316
donk_316 is offline
Can't you just use 200mm tire night train parts? 2007+?
Sorry I see you want 250... yeah maybe a breakout frame and swing arm?
Old 10-18-2018, 12:52 AM
j33ptj's Avatar
j33ptj
j33ptj is offline
What do you mean, the wide tyre craze is over... is it now old skool?
Old 10-18-2018, 04:51 AM
magna's Avatar
magna
magna is offline
probably Harley's always seem to be behind the curve on things, I think most bike builders now think 200 is as far as you need go for looks and handling, still riding a Harley is all about being unique so ride what you like.
Old 10-18-2018, 02:41 PM
bustergut's Avatar
bustergut
bustergut is offline
Would this work?
​​​​​​​https://ricks-motorcycles.com/en/parts/schwingen/schwingen-softail/fat-***-kit/
Old 10-30-2018, 09:58 PM
JohnK-NJ's Avatar
JohnK-NJ
JohnK-NJ is offline
I do not have the original fender on my 2002 fat boy but I have an 18 inch wide rim on it and run a 180 tire on it now and if I switch to a chain and sprocket I can fit a 200
hellonewman
02-13-2020 10:18 AM
Cobrettysw
11-18-2012 09:15 AM
MOBANN1
07-19-2009 04:47 PM
mwilson_79
03-30-2008 08:16 PM
Quick Reply: how to fit the biggest tire on a 2002 train
