FXFBS Dominion Rear Axle Nut Cover
Hi,
Some videos i made yesterday.
https://www.dropbox.com/s/xbuxsn77u6...94353.mp4?dl=0
https://www.dropbox.com/s/jx6oxb1ioz...94524.mp4?dl=0
https://www.dropbox.com/s/heee3j9qac...94619.mp4?dl=0
What i'm doing wrong?
Does the 2019 FXFBS and later 2018 models use different axle nut sizes?
After viewing your videos, I can see why you're concerned with loose fitment on the left side. Although I've never installed rear axle nut covers, I've installed several pairs of front axle nut covers, and loose fitment such as yours was not uncommon. Once the set screws are tightened, installation is complete, even though the cover is slightly off center. Orientate the set srews perpendicular to a hex flat near six o'clock so they are less visible. Apply blue loctite to the set screw threads. The set screws come with pre-applied thread locker, but it may have worn off if you've ran them in and out several times already.
Edit: I noticed the instructions I posted in post #3 are obviously incorrect for your application. It shows the deep cover with the short screw belonging on the left side. The deep cover with the short screw should be on the right side. Wouldn't be the first time P&A instructions were incorrect.
heljag (11-25-2018)
The covers are a multi-fit accessory. They were not made to fit just your specific model and year alone, but a variety of models manufactured as early as 2008. There are slight variations in axle nut size amongst these models. The longer set screw compensates for these slight variations.
