squeaking type of a noise
I have a 2005 softail deluxe. i bought it used last summer, it has 17k miles on it. it has been taken real good care of, well it looks like it has.runs great. when throttling at a normal speed i don't hear anything, and if i run it up fast i dint hear anything. when i rev it some sitting still it doesn't make a sound. but when you are going up hill or just giving a little throttle, kind of lugging like. it makes a weird squeaking or rattle type metallic sound, its coming from the right side. Hard to describe. any ideas. would the cam tensioners make a squeaking kind of sound if they are worn. I haven't pulled the cover off yet to check the adjusters. I've checked every bolt and nut i can think of and everything seems tight. unless I'm missing something. thanks
I’d stick to the things on the outside of the bikes motor to . Commonsense is things that are lubricate with oil don’t generally squeak .
Also did you do anything to the bike in the past month or so .
I’ve tried to tighten everything I can . It sounds more external than internal , I think lol . But I can’t find anything and the only time it does it is while riding , so I try to look down and try to pinpoint but I almost crash lol . Not really funny but it drives me crazy . I haven’t changed anything . I may try to mount my go pro on crash bar and see if I can get the sound recorded. I’ll try to post that and see if anyone has a idea .
This is going to sound crazy, but check your floor boards. My bike was making a squeak/tick at idol and low rpm. Sounded like a cross between a squeak and a ticking lifter. And since it only made the noise when the bike was hot, I was thinking I had a bad lifter. Turner out of be one of my floor boards making the noise. Tightening the bolts and a little WD-40 did the trick.
