I am in search of the mounts to put the front turn signals back on the handle bars. I have checked Ronnie's and he has the picture of them but does not list the part numbers. So if any of you know where I can get some any help is much appreciated.
From Ronnie's you will need the following … these are all listed under Front Turn Signal
2 of 7744
2 of 67822-88
2 of 67827-88A
1 of 67831-03 right side
1 of 67829-88 left side
2 of 7744
2 of 67822-88
2 of 67827-88A
Thanks, I wasn't sure if that was all I needed from looking at the pictures. Thought I might have needed 7 and 8 from the photo.
Items 7 & 8 do not go on a 2006, they are for a different year/model … the items I listed above should be what you need … the right side item 12 will attach directly to the bottom of your mirror stem, left side item 13 the mirror stem goes through the hole in the mount
Did you move the turns or did the previous owner? If someone else moved them, make sure you have enough wiring to put them back up on the bars. Just a thought.
Gotcha, really appreciate the info, I had no clue what the mounting brackets looked like. Oh there is plenty of wire, he didn't shorten anything I have already taken them off once before and they reach with wire to spare.
